Cylinder 6 plug fouled?
04-11-2012, 09:06 PM | #1 |
Rep 6,631
Got around to doing plugs today, and it appears cylinder 6's plug threads were covered in oil and plug tip covered in carbon (maybe oil residue)?
Doing some digging on e90, it appears the valve cover gasket may be the issue. Anyone here experience this and did the valve cover gasket resolve the issue? I found nothing overly conclusive. edit - the coil pack was dry when pulled.
E90 LCI N54 6AT
04-11-2012, 09:22 PM | #4 |
Reborn
87
Rep 1,217
I would do a compression check. Was there oil on the other end of the plus (where the coil pack goes)? If not, I doubt it's the gasket. In fact, a leak at the gasket wouldn't make it past the threads to the electrode end. If it's oil, IMO you have a ring issue (or valve stem seal). It's it's carbon, perhaps an add fueling issue. I'd do a compression test to eliminate a ringland/ring issue.
04-11-2012, 09:27 PM | #5 | |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
A leaky valve cover gasket wouldn't wet that tend of the plug unless it got wet during installation. You should be able to shine a light down in the spark plug hole and see if there is oil on the walls. If so, the valve cover is definitely leaking. If not, it's coming from the combustion side. |
04-11-2012, 09:44 PM | #6 | |
Rep 6,631
The coil pack was dry, only the threads were soaked in oil, as you can see in the picture. The electrode itself appears to be covered in carbon. I just can't buy the fact I could potentially have two issues in the same cylinder? I truly believe that the deposits on the electrode are burned oil and not fuel. If it were fuel I would definitely look into replacing the cylinder 6 injector. The car does not have the symptoms of a failing injector (car does not misfire, car does not rough idle on a cold start, car runs fine from what I can tell). I will check the spark plug hole for cylinder 6 with a flashlight and see if the threads are covered in oil. Then again, if the valve seal gasket and leakdown tests do not fix the problem, it may be time to buy into the fact something's broken in there. I don't really think so though since the car runs fine.
E90 LCI N54 6AT
04-11-2012, 10:11 PM | #7 |
Rep 3,456
Drives: Harrop E90 M3
Do you think it's possible that there is a crankcase ventilation issue on cylinder 6? Perhaps the low pressure side of the ventilation system has a leaking check valve (in the valve cover) that is leaking under boost?
If your cylinder leakage test turns out okay, maybe it's worth looking into. I'm sure you know to do the cylinder leakage test with the engine hot, so I hope your results come out in the acceptable range. Do you have or have access to a bore scope to get a good look at the cylinder walls? Perhaps you have a valve seal issue causing the oil build up also? Am I correct in the fact that you have RBs? Did you notice any oil build up on the exhaust valves or the #6 exhaust port when you installed them if so? You may pop the intake off and try to determine if the valve seals are leaking, which may be tough with the typical carbon buildup. That's a lot of ideas, but you may run out of other ideas on your own. Definitely keep us in the loop! |
04-11-2012, 10:23 PM | #8 | |
Reborn
87
Rep 1,217
04-11-2012, 10:23 PM | #9 | |
Rep 6,631
E90 LCI N54 6AT
04-11-2012, 10:26 PM | #10 |
Reborn
87
Rep 1,217
And I've blown many a motor, and even when I had 60psi in a cylinder, the plugs were not soaking wet nor had burnt oil (the ringlands were cracked, but nothing catastrophic). I'd think burning that much oil would show through your exhaust and, if it was coming past your rings, on the compression test.
How many cranks did you do and which order did you do the test (1-6, or 6-1)? I normally do it twice to make sure it isn't a temperature / fuel washed-induced inconsistency. |
04-11-2012, 10:49 PM | #11 | |
Rep 6,631
Apparently the correct way to do a compression test is to crank the motor until it stalls out? Car starts right up, doesn't misfire, no codes, idles smoothly, no issues as far as I can tell. Car makes plenty of power (stock turbos or RBs), good enough for 118 mph in the quarter mile on stock turbos, full weight, stock wheels/all-season tires. I do have an ignition timing flatlining issue, and I am going to check the injector coding as well tomorrow to see if that can be related. I doubt it since the car does not flat line timing on the stock tune.
E90 LCI N54 6AT
04-11-2012, 11:12 PM | #12 | |
Rep 474
I'm not sure how you might hold the throttle blade open? Were you cranking by jumping the starter leads or by using the start button? Once you figure it all out let us know!
//ecg//
04-11-2012, 11:21 PM | #14 |
1740
Rep 17,960
Drives: A Lot
You don't need to hold the throttle blade open. Just unplug the connectors going to each of the fuel injectors. Remove all 6 plugs. And then test each cylinder with 10 cranks. Pressure will stabilize after the 6th or 7th crank. It's also useful to know what pressure is on the 1st crank but that requires two people.
shiv |
04-11-2012, 11:23 PM | #15 | |
Rep 3,456
04-11-2012, 11:25 PM | #16 |
3441
Rep 79,211
Compression test are not done to crank motor over. You dont want the motor to crank over that is why you disconnect injectors and coils.
You just want to turn over the motor until you get your highest reading on the gauge. However many cranks it takes is usually what people go for but it should be around 5-10. Usually something around 180 PSI. The build up past the threads is interesting, initially I thought it may be a bad injector though until i realized the black went further up. Not so sure now. Usually if the coilpack is oily its the valve cover gasket. |
04-11-2012, 11:32 PM | #17 |
Rep 6,631
Wouldn't know, I had them installed for 200 miles. But haven't lost any oil yet.
No blue smoke out my tailpipes or anything either. I am wondering if running that BSH OCC for a while may have contributed to this issue? Cylinder 6 is quite close to the pcv tubing. No OCC as of around 4000 miles ago.
E90 LCI N54 6AT
04-11-2012, 11:56 PM | #18 | |
Rep 2,626
but this is a good point either way and I think it's worth buying the BMS OCC as a precaution.
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-12-2012, 12:09 AM | #19 | |
Rep 6,631
Perhaps the oil collected on the plug was just residual from back when I had the BSH OCC installed, and the oil collected immediately on the new plug just remnants from that? It's been 4000 miles since I removed the can. I will do a proper compression test, clean the spark plug hole, try an old clean plug and see if it fouls right back up. Is there any definitive evidence that the coil pack sleeve would be covered in oil on this platform? I have dug through this site extensively and found nothing that visually confirms that the coil pack would get oil on it on a bad valve cover gasket.
E90 LCI N54 6AT
07-24-2012, 06:13 AM | #22 | |
Rep 1,311
