BMW M3 Forum (E90 E92)
      04-09-2012, 10:03 PM   #1
bigjae1976
bigjae1976's Avatar
1570
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
DIY: Schroth Ralleye4 Harness install
Do KNOW that Schroth approves these harnesses in conjunction with a particular seat. To my knowledge, Schroth has not produced a harness that is tested and DOT approved for use with the E9X M3 OEM seats. Do this at your own risk.
My thinking is that I'd rather that the risk using a seat that is not fundamentally different from the E46 this harness was designed for. That's a trade off that I will make at this point vrs driving with the OEM lap belts which just don't cut it. Even if you pretension the belt, my mind would focus on bracing myself vs concentrating on keeping the pavement under the car.
1. Take out the back seat. If you need directions on how to do this, just close internet explorer and take it to a professional.
2. Take out front seat. First, disconnect the battery...not necessary. Just don't turn the ignition on, you'll get an airbag light. Easy...4 T50 bolts. There is a connector underneath, just lift the black tab on the yellow connector. Insert a small screwdriver under the tab on the white connector...
3. Remove cover from outboard seat belt anchor. You need to be a man. Take a prybar and stick in the back like this...
4. Don't pry but twist the pry bar. You will hear a distinct snapping sound. That is normal for BMW interiors, they are well put together. This is what the little bugger looks like from the back.
5. Remove this bolt.
6. Get your harness, clip your lap belt together and lay the shoulder straps over the head rest...make sure nothing is twisted. Otherwise, you'll be repeating all of these steps
7. Install the outboard front anchor. You will need to bend the anchor outward, otherwise it will dig into the bottom of your side bolster unless you drive with the seat laid flat...like they do in da hood. I just laid the seat back flat, installed the anchor and pulled the strap to bend it.
8. Install the inboard front anchor. Remove the T50 bolt holding the belt tensioner.
9. The bolt does not fit in the hole in the harness anchor. I used a step bit to bore it out to fit. Doesn't take much. Replace the bolt.
10. The hard part is done. Reinstall the seat...x3 check that the shoulder straps and lap belt isn't twisted.
11. Install the rear strap...not hard. Again, T50 bolts. Replace the rear seat. Bend the achors as needed.
12. Done.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      04-09-2012, 10:08 PM   #2
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
How to stow your harnesses. My video may lack clear visual instructions...let me know if you can't figure it out.
      04-09-2012, 10:34 PM   #3
adc
Drives: 2018 F80 M3 ED
Thanks for the post, very helpful.
Couldn't tell from your video how you stored the rear straps - would you mind terribly sharing your experience there? (like, do they fit under the seat?)
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      04-09-2012, 10:36 PM   #4
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
You can stow them under the seat...I just leave them there...keeps the kids busy.
      04-10-2012, 08:57 AM   #5
von_zoom
von_zoom's Avatar
30
Drives: 2010 Z06
Thanks. Very simular to my 525 belts.
vz
Previous Track Toy
      04-10-2012, 09:16 AM   #6
RayC
RayC's Avatar
South Korea
13
Drives: E90 M3
Hmm...didn't know how to take off that plastic...gonna have to give it another try.
      04-10-2012, 11:23 AM   #7
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
Just make sure you pry from the back of the seat. Otherwise there is a tab on the front that you'll snap.
      05-07-2012, 06:27 PM   #8
TX335
Drives: 08 E92 M3
How do you deal with the seat belt warning that will come up without the OEM 3 point being buckled? Do you just ignore it?
      05-07-2012, 07:08 PM   #9
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
I tried to ignore it...didn't work. I'm running solo in most cases so I just plug the pass belt into the drivers side. If you have an instructor...the beeping will eventually stop. I guess your could try to see if the rear center belt in an e90 can reach.
      05-07-2012, 10:11 PM   #10
adc
Try one of these: http://www.ebay.com/itm/BMW-M-Emblem...#ht_4193wt_972
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      05-07-2012, 10:15 PM   #11
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
For the harnesses to work properly, I believe that you'll need a harness bar at a minimum to position the belts at the right spot. From what I recall, they aren't supposed to go at such a steep angle after they leave the top portion of the driver's seat. Please correct me if I'm wrong though.
I do like this install MUCH better than the other one posted on here.
      05-07-2012, 10:43 PM   #12
TAAXED
TAAXED's Avatar
Australia
Drives: Golf
I THINK this is designed to work without a harness bar right? I can't remember exactly what they claim but I have the exact same harness setup in my car right now. I've used it once on the track and it worked extremely well.
2010 Porsche 911 GT3 (Carrera White/Black)
2010 BMW e92 M3 M-DCT (Frozen Grey/Black) - Sold
2007 BMW e92 M3 6MT (Jerez Black/Palladium Silver) - Sold
2002 BMW e46 M3 SMG (Titanium Silver/Black) - Sold
      05-07-2012, 10:49 PM   #13
THE TECH
THE TECH's Avatar
307
That's out the window since bigjae states that the setup is not made to work with the e9x seats.
      05-08-2012, 07:54 AM   #14
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
I don't imagine the actual E9X production harnesses being much different. I hope the tailstrap is longer. In the pic, the tail strap is adjusted to max length. So these might not work as well if you have short legs and a beer belly or you drive with your chest against the steering wheel.
The ralleye4s aren't vehicle specific like the quick fits either. Schroth advertises that these 4pts have antisumarine technology (ASM)...whatever that is.
After using these for 2 events, I feel the improvement far outweigh the potential risks. Your not beat up and worn out from trying to keep yourself in the seat.
      05-08-2012, 08:25 AM   #15
TAAXED
TAAXED's Avatar
Australia
Drives: Golf
^ Yeah I was referring to their ASM technology...I guess we take a risk either way on-track, it's up to you to decide what's more important to you.
      05-08-2012, 08:02 PM   #16
RayC
RayC's Avatar
South Korea
13
Drives: E90 M3
Originally Posted by adc View Post
That's very nice...I have some generic version and I think I'll swap it out.
Good find!
      07-29-2012, 06:15 PM   #17
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
Just to revisit this...you should read the directions before installing and using these harnesses.
When you adjust the harnesses, you have to tighten the lap belt first so it is tight and goes over your hips and the buckle is low in your gut. THEN tighten the shoulder straps. The buckle should still be low in your gut. Its usually right on my waist line. For those old fashioned people...below your belly button. If you have the buckle higher than that, its no good. First, it defeats the anti-submarine technology. Second, you'll look like a dork and people will laugh at you.
The schroth instructions shows pictures of how the harness should look.
      08-01-2012, 07:54 PM   #18
Purplem3pursuit
Drives: AW/BL E92 M3 Competition
I didn't see any discussion of E92 vs E90 seats... I have been looking around and haven't found anything but did check RealOEM and the part numbers for the frames were different. Can anyone confirm that the mounting configuration used for the E90 is applicable to the E92 (specifically the seatbelt... E92 has the slide rail on the floor)? I would assume the frame construction is roughly the same but does the seatbelt bolt exist on the E92 seat?
Alex
Moderator at M3F.c
      08-01-2012, 08:22 PM   #19
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
On an E92, you'll need to use the bolt that holds the bar which the OEM belt mounts to.
Its on the rear floor I believe. You'll just need to bend the bracket up a little.
      08-01-2012, 08:31 PM   #20
Purplem3pursuit
Ya that's what I was trying to avoid... Didn't want to deform the bracket anymore than I needed to..
Alex
Moderator at M3F.c
      08-01-2012, 10:06 PM   #21
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
It's meant to be bent a little. Mine are. Just can't keep bending it back and forth.
      08-07-2012, 08:54 PM   #22
Purplem3pursuit
Further info for E92s
I went ahead and took the liberty of pulling the side of the seat to see if there was the possibility of being a bolt for mounting the harness.. No dice... we Have to stick to the floor mount...
Alex
Moderator at M3F.c
m3post
