E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Adding a Phone kit for 2007 325d?
      04-04-2012, 12:16 PM   #1
jamphi24
Drives: BMW X5 25D 2015
Hi
Recently just bought a 325D 2007.
It has all the buttons on the steering wheel and head unit but does not appear to have the actual phone feature?
Sorry I am not very knowledgeable on this sort of thing . But is there a module I can buy for bluetooth, or a way to cable connect the phone or something I can do to make these features work? Not too expensive i hope!
Thanks
      04-04-2012, 09:46 PM   #2
taibanl
taibanl's Avatar
281
Do you have 6fl usb in armrest?
      04-05-2012, 06:18 AM   #3
jamphi24
Hi, no it doesn't. Thnks
      04-05-2012, 11:49 PM   #4
Thumperx
Drives: 335I coupe
Originally Posted by jamphi24 View Post
Hi
Thanks
If you want to use your phone to make calls via the car's integrated phone system (SA640) and Bluetooth abilities, you’ll need the following:
MULF2 high (any recent year MULF from BMW or Mini can be used)
MULF trunk bracket (included in purchase)
Microphone (placed in the overhead console switch unit)
Bluetooth antenna (located and placed in the driver’s foot well)
Coding (perform at BMW service, person with "Autologic” program CPU, or other data interface abilities).
A good reference of procedure (DIY) is from Lazd & Armito (not exact component/s installation, but very close). Follow the BMW retrofit PDF for exact install (provided).
http://www.e90post.com/forums/showthread.php?t=660738
http://www.e90post.com/forums/showthread.php?t=482939
Installation is fairly simple and straight forward. Just follow the installation from the DIY and place the associated wiring correctly, then coding should not pose a problem.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
e90post
