Gas smell after installing Procede
03-31-2012, 10:42 PM | #1 |
Rep 84
Ok, I have had my Procede rev.2 out for a few months because I had the car in for oil change and spark plug service and never put it back in. No problems at all stock, except a little rough idle which apparently is a problem after getting plugs. The car has 42,000 miles.
So, I sent in the rev.2 for the rev.3 with NLS. I installed it, and everything seems to work fine. However, when I get on it and go through a couple gears, I distinctly smell gas. This does not happen unless I get on it. I tested this 3 times by driving normally with no gas smell, and then gas smell once I get on it. I'm on map 1, car has no other mods. I don't think there's anything wrong with the Procede, but this problem clearly appeared with the installation of it. There are no check engine lights or limp mode or anything. I wonder if it's the map because the rev.2 map was fine. Perhaps this is unburnt fuel?? I'm not sure where the smell is coming from. I don't think it's the engine bay. I smell it right away inside the car. Thanks if you can help!
2007 BMW 335i, Jet Black, Sport, 19" Wheels, custom trim, m shifter, Procede v5 Rev.3
369rwhp, Best 1/4 12.8 @ 108 2003 Hyundai Tiburon GT, Supercharged (stage 2, 280whp), Full mods, meth, coilovers, wheels, full stereo 2004 Suzuki GSX-R600, flush signals, undertail delete, carbon fiber exhaust |
03-31-2012, 10:57 PM | #2 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
03-31-2012, 11:02 PM | #3 | |
Rep 84
03-31-2012, 11:45 PM | #4 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
I would definitely burn a qtr tank and then rip her open the following day. I had the same thing happen with my Ducati when filling up the tank to full and parking in garage smelled like gas. Notice it was a gas leak and Ducati told me is the tank design. It pores out excess gas when tank is full and bike is stationary. So I now just make sure I fill up well before I get home
I will try to burn some gas and run her again the next day. If same problem occurs, try older maps to see if it is a Procede issue cause by the AFR when you open her up.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
03-31-2012, 11:48 PM | #5 | |
1737
Rep 17,960
Drives: A Lot
03-31-2012, 11:55 PM | #6 |
Rep 4,771
If it is the raw smell of fuel. The exact same that you get when you sniff the pump (not recommended) then you are smelling fuel before it goes into the engine. That immediately rules out the tune. I would have the dealership or an experienced mechanic take a good look at your tank, fuel lines, etc. Once it combusts, the smell changes in my experience.
A tune would have no effect on this. |
04-01-2012, 12:53 AM | #7 | |
Rep 2,197
Raw fuel and unburned fuel smell totally different. If it smells like gasoline then you need to be careful and investigate immediatley. |
04-01-2012, 05:03 PM | #8 | |
Rep 84
04-01-2012, 06:14 PM | #11 | |
Rep 2,013
It wasnt a gasoline smell more of a burning smell.. |
04-01-2012, 06:27 PM | #12 | |
Rep 3,177
you can see what adaptations are reset in the procede command center. i fail to see the correlation between any of those adaptations and a fuel smell, but ok. |
04-01-2012, 06:46 PM | #13 | ||
Rep 2,013
I dont know why it did that, but thats probably why shiv always recomends to reset adaptations when installing the procede? Anyways good luck figuring it out op. |
