Log : Cobb Stg2+FMIC Aggr v401
03-31-2012, 06:40 PM | #1 |
Rep 169
Was hoping to get some insight on the log I captured today. Mods are in my signature.
I'm getting a timing correction on cylinder#1 and throttle closures. Is this likely a bad coil pack? Boost is kinda rocky as well. How is the timing profile? standard for this map or low?
|Cobb AP / JB4 | DCI | BMS WW Meth Kit | AMS FMIC | Macht Schnell 3" DP |
03-31-2012, 10:05 PM | #2 |
Rep 1,154
Is it normal for the tps to close like that for stage 2? Maybe because of the boost spiking, idk.
The A/F are bouncing between 11.5-12.0, I was just logging my stage 1 v401 and was flat lining 12.2. Cylinder 1 seems to be a common problem on most cars logs, mine being one. Swapping coil pack would be where to start. |
04-01-2012, 10:33 AM | #3 |
Rep 169
Thanks for the review. Yeah, I'm not really clear on TPS closures cause and effect wise.
I didn't look that closely at the AFR ratio. However, it seems to represent a harmonic oscillator dampening as it approaches ~12.0 not sure if this normal or not. I'll try swapping coils and see what happens. I'll re-post log in the Cobb thread. Should have been there anyway my bad. Did you post your log?
04-01-2012, 09:11 PM | #4 |
Rep 1,154
I never posted my logs. I'm not a pro but I think my logs looked good enough. Car drives amazing on the V4 software.
I don't think harmonic oscillator dampening has anything to do with a/f. Mine is locked in at 12.2. Somethings are better to look at on a spreadsheet rather than a graph IMO. |
