Making over 20psi on stock turbos...due to misfires?
03-31-2012, 02:11 PM | #1 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
So I'm still on the stock plugs now with over 30,000 miles and I've been modded since the day I bought the car with 7 miles on it. Very recently I started misfiring. Started with cyl 1, and now (after 2-3 weeks, I'm misfiring cyls 1, 5 and 6 intermittantly. Going to buy plugs today and hopefully that will cure the misfires. I did a log to see the effect of the misfires at WOT, if any.
This is a data log from a dead stop on a slight incline at 800 ft altitute. My boost curve has been modified in an attempt to remain at 13-14psi up to 4,000 RPM and then ramp up to 17psi at 4,500 and taper to 15-16psi at redline (in an attempt to maximize traction from a dead stop with 19" wheels). To my surprise, I hit 20psi briefly in 2nd gear and sustain 20psi in 3rd. AFR's are rich and timing low in 3rd gear, so I think acceleration is suffering....but I have no idea whether that has to do with the possible misfires (on this run) or the high boost/low timing. Will swap plugs and see if this does anything. Curious if you guys with misfires are seeing anything strange in your data logs.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
03-31-2012, 02:55 PM | #3 |
Rep 6,631
PS: you're flatlining timing. Whatever happened to this being fixed? Every auto Procede log i've seen shows this flatlining behavior.
Back OT, if you misfired, your car would throw an SES light and the car wouldn't build any boost and sound like it has cams. Time to change your plugs.
E90 LCI N54 6AT
03-31-2012, 03:05 PM | #4 | |
Rep 6,771
Drives: 2016 BMW i8
I'm going to lower my boost settings (0% and 100%) in the Procede after I get new plugs to see if by doing that it helps timing/AFR's.
03-31-2012, 03:10 PM | #5 | |
Rep 6,771
Drives: 2016 BMW i8
That's why this is strange. It's targeting 17 psi but hitting as high as 20.7. I thought maybe the misfire was to blame but I guess logically doesn't seem to make sense. Misfires seem really common so maybe others are seeing this too.
03-31-2012, 03:16 PM | #6 | |
Rep 6,631
E90 LCI N54 6AT
03-31-2012, 03:18 PM | #7 |
3441
Rep 79,211
That may not be actual boost, is your throttle closing? You need to log CAN DBW. If your throttle closes it will induce an inflated reading of boost.
03-31-2012, 04:10 PM | #8 |
Rep 6,771
Drives: 2016 BMW i8
Not on this run, went WOT from a dead stop in 2nd gear and didn't lift off the accelerator as I paddle-shifted to 3rd gear.
03-31-2012, 04:11 PM | #9 |
Rep 6,771
Drives: 2016 BMW i8
That would suck. I'm getting misfires in 3 different cyls so really hoping it's just old dirty plugs.
03-31-2012, 04:13 PM | #10 | |
Rep 6,631
I highly doubt that is the case though because you are sustaining high boost post-shift. It's not uncommon for the Procede to show boost creep on long pulls due to EGTs rising under sustained load. I got plenty of logs showing similar behavior from when I ran the Procede.
E90 LCI N54 6AT
03-31-2012, 04:50 PM | #11 |
Rep 1,943
R u still on stock DPs?
I don't think is easy on the turbos to push that much psi with stock Turbo Back Exhaust
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
03-31-2012, 04:51 PM | #12 |
Rep 6,631
Look at his sig.
E90 LCI N54 6AT
03-31-2012, 05:34 PM | #13 | |
Rep 6,771
Drives: 2016 BMW i8
Check out this log - it's from my race against you at the airstrip event. My meth boiled over in the lines waiting forever on the hot taramac and so my meth didn't flow. Check out the 80c inlet temps. I think I could have ran faster! lol
03-31-2012, 05:38 PM | #14 | |
Rep 6,631
E90 LCI N54 6AT
03-31-2012, 06:21 PM | #15 |
Rep 1,943
I actually meet him before and his wasn't running aftermarket. I'm also on my iPhone app so signature are not available
03-31-2012, 07:08 PM | #16 | ||
Rep 1,943
03-31-2012, 07:31 PM | #17 | |
Rep 2,841
Ran three just like this one today: 6AT Running the latest dynamic meth maps. i can still flatline once in a while, but it sems to be more the exception than the norm. I don't think Shiv did anything to address the issue. Doesn't seem to happen on ALL procede 6AT's. I remember you switching to JB and Cobb and still flatlining on those tuning platforms yourself. I was watching closely because I would have jumped ship had that problem been solved, but from what I see......it isn't. |
03-31-2012, 07:39 PM | #18 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
+1
The flatlining issue isn't tune-specific, but rather a result of knock control activity. Running more boost without supporting octane/mods will make it happy more often. I suspect exhaust backpressure is the biggest contributor to this issue which is why octane only helps up to a point. If you are running the stock turbos at high boost, it's likely to happen. With 6ats, it's more likely because they boost spike at the upshift instead of dipping between gears as on a 6MT. Ps... Nice logs Ilma. 16-17psi with full advance is really the sweet spot for a stock turbo car. Trying to support over that makes things less consistent (although still faster). |
03-31-2012, 07:41 PM | #19 | |
Rep 2,841
The engine feels happier there |
03-31-2012, 07:44 PM | #20 |
1737
Rep 17,960
Drives: A Lot
03-31-2012, 07:47 PM | #21 |
1737
Rep 17,960
Drives: A Lot
@Longboarder, just drop your boost. The more boost you try to run up top, the bigger your upshift boost spike will be. This is because the high rpm/high boost scenario, makes those turbos spin so fast they cannot deccel quick enough as the RPM drops. Lower engine RPM+same turbo RPM= more boost. And if boost is much greater than boost target, you will likely see a timing reduction.
03-31-2012, 08:03 PM | #22 | |
Rep 6,631
If you're up for it, I can link to those threads. And can you explain why I flatline in the 6000-6400 range, but not below 6000 but not above 6500+ RPM on Cobb? It CAN be tuned out. You just don't know how. And furthermore, it appears something your tune is doing makes the timing flatline even worse on your tune than on other tunes such as Cobb and JB4. If we could see what specifically your tune does that causes timing flatline to be even worse than on other solutions, it could be a start for all of us to have a fix. And it's troubling because being short 10+ degrees of timing will be a major impact to performance. PS - It has nothing to do with boost pressure. Ilma flatlined timing on low boost (14 psi). I've flatlined at 16 psi. Not trying to thread jack, but it's interesting to see a purported tuner do a complete 360.
E90 LCI N54 6AT
