STETT intercooler: Engine heating issues?
03-31-2012, 02:30 AM | #1 |
Rep 623
I have been doing alot of research about intercoolers and the concept of how they work and what potential benifits they provide. I'm FBO minus an intercooler since I bought the car in the winter time and did mods accordingly. The only thing I have left is meth and an intercooler and need your guys opinions. I track the car occasionally when there is a special event going on in my area which is probably once every couple months, if that. Summer is coming, well really already here and need to pull the trigger on an intercooler by next week.
I know the STETT intercooler is one of the best intercoolers but I have some questions/concerns about it. -Since the STETT intercooler blocks almost half the radiator. Common sense tells you that if you block the radiator, your motor isnt going to get the cooling capacity as it would if something wasnt blocking almost half of the radiator... -With STETTS intercooler its recommended to do charge pipe/diverter valves which is a pretty good chunk of change if you add both of those together. -STETTS inetercooler is by far one of the best intercooler because it has SO much surface area for air to get absorbed. -Another thing is how expensive it is compared to other top quality intercoolers. This car not going to be a racecar but just really a very fast DD and take it to the track occasionally like I said earier. Its actually one of the more expensive ones but it gets the job done... well what it was designed for. But in the real world the motor of the car is the heart and soul of the car and blocking the radiator even just a little bit could have a major effect on the motor. I know there is a TON of other top qualities intercoolers that dont block the radiator such as the ETS, HPF, HELIX ect..I have come to the conclusion that most of these intercoolers do pretty much the same job. What I was curious about is will I get the same cooling effects going with any one of these mentioned above? I know I will be saving alot more money on the STETT but it just doesnt make since to me when I can get baically any one of those that I mentioned above, along with the same benifits. And the above mentioned ones can support pretty much any power level you can put the N54's I love the STETT intercooler and have a few of his products and they are some quality craftsmanship. I just dont want to block half of the radiator because its just going to make the motor get hot. Im really liking the HPF and the ETS just by the quality and how you dont have to do alot of trimming to the car to get them set in right. so what do you guys think I should order. Im just not diggin the blocking radiator thing with the STETT's intercooler when I can have the same cooling effects with one that doesnt block the radiator? I just think thats kind of a big deal but this is why I love this forum!!!!! |
03-31-2012, 07:46 AM | #3 |
Rep 2,567
Value for performance, I'd say go with ETS intercooler. It also comes with additional piping to connect to the charge pipe.
For our cars, since the front opening is not as big as like an EVO, it's better to get intercoolers that have more depth rather than height. These types of intercoolers will have better performance. The bumper will block majority of the height of a tall intercooler. I read this on the forum somewhere. Someone correct me if I'm wrong.
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
03-31-2012, 09:12 AM | #4 | |
Rep 2,856
Drives: 2011 335is E93
I would look for an FMIC that comes complete with all hardware and no additional pieces are required so that you have a smooth install. If you already have a CP/BOV then that might also be important in your choice factor. As TT3 mentioned it comes rdy for CP matching for easy install; I would stick to FMIC's that come like this. At the end of the day though it's up to you. You get what you pay for in most cases. |
03-31-2012, 09:19 AM | #5 |
Some dude
92
Rep 1,780
My vote is also to NOT block the radiator for any kind of car. The giant hole left from the stock intercooler also allows more air in under the front of the car = lift, AND that opening allows the air entering the nose to bypass the radiator = even hotter operation. Even if you block off the old opening completely, it's just not a great idea to block your heat exhangers. Also, you're blocking the evaporator, which makes the AC work harder in the summer.
For a street/DD/fun fast car, any of the other stock location ICs will be just perfect.
RRT
E92 335i/6MT with stuff and things |
03-31-2012, 09:29 AM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Most of the stock fit FMIC’s will manage airflow for over 475whp. Some are more efficient then others but all are better then stock. No need to block the radiator.
Water cooling is important enough that the IS which is about a Map1 boost has an additional water radiator & a faster fan system.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-31-2012, 09:52 AM | #8 |
Rep 1,244
Since these threads always turn into recommendations of what we all own, I'll throw my worthless opinion in here and add the ER. I've been extremely pleased with the performance and it doesn't block the radiator either.
03-31-2012, 09:55 AM | #9 |
Rep 2,558
Imho, get ams or helix... No compromises... The hpf is overkill for me, but maybe if you plan on doing a single turbo in the future might be worth it... If you want value, ets.
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
03-31-2012, 10:13 AM | #10 | |
Rep 887
Helix IC also blocks a portion of the radiator but it doesn't seem to be as bad as STETT. OP you may want to look into Helix. Heard good things and will probably be the FMIC I end up getting eventually. |
03-31-2012, 10:19 AM | #11 |
Rep 6,631
trimming is a bitch and a half ... been there, done that. Stick with the 5" ETS FMIC unless you plan on going for HUGE power (over 600 whp). Trimming easily adds an hour to the install if you plan on doing it without removing the bumper. Other platforms use FMICs even smaller than the 5" ETS FMIC making huge power.
E90 LCI N54 6AT
03-31-2012, 12:16 PM | #12 |
Rep 623
Ya thats exactly what I was leaning towards is either the ETS 5" or the HELIX. I actually helped a buddy install his HELIX on his N54 and we did it on ramps lol. It took us a total of about 2-3 hours to take out the factory intercooler, barely drimmel the shroud just enough for it to squeeze in, then put it up there. Wasnt hard at all even it being on a set up maybe 1 foot ramps lol. 2 people is def a must though to hold the intercooler in place and have your buddy tighten the screws down. The HPF is def a bad as# design and I love the mounting plate that they fabricate to hold that intercooler up there very professional in my opinion. Realisticly Im not making this car into a single turbo blown out race car, but just a 450whp-500whp DD that is still reliable and fun to drive and occasionally take it out to the track I know the 5" ETS would probably be my best bet and I have heard great things about both. Thanks guys, I LOVE THIS FORUM!! So now its between the 5''ETS or the HELIX and just maybe the HPF depending on what kind of deal I can get on it
03-31-2012, 12:46 PM | #14 | |||
Rep 118
Here are two interesting posts that explains it pretty good: Quote:
04-01-2012, 01:03 PM | #15 |
Rep 623
I know more height can absorb more air but I would rather not block off half of my radiator that IS the cooling system of the actual MOTOR itself. It just doesnt make since that I would block half of another cooling part (which is a very very important part being the radiator) just to make my intercooler absorb and cool more air for the turbo's...From what I have heard from everybody and doing my research, I think Im going to do the ETS 5" or HELIX. The ETS 7" requires quiet a bit more drimmeling and cutting for it to fit in its space. So Im just seeing how much I would have to cut/drimmel to make it work. Im ordering it monday meaning tomrrow so i just want to do the right one and now I have my mind set thanks to you guys!!!
04-01-2012, 01:14 PM | #16 |
Rep 2,626
I went with ets 7" after long research. It's an amazing inter cooler that comes with couplers and piping that connect it to the charge pipe . Im very happy with the performance as well . To give you an idea I used to get around 25F increase in IATs on the stock map in 3rd gear, now my IATs are constant in 3rd gear on stage 2+ sport !!! I love this mod
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-01-2012, 03:04 PM | #17 | |
Rep 647
04-01-2012, 11:58 PM | #19 |
Rep 623
I think the ETS 5'' can handle RB's to be honest. The RB's give you great gains dont get me wrong and probably the absolute best when it comes down to value. Me, personally think that the RB's make everything work easier since the way he builds them and the materials he uses. Honestly if you want a car thats not going to break and still be a DD the RB's by far are my pick of choice. The price isnt bad either considering what he actually does to the turbo's themselves. Thats alot of work and everything has to be precise when doing this type of work which Rob Beck is known for. Im going to use the stockers until something happens to them so I have an excuse to get the RB's....really I might want to do just all of it at once lol but I know the RB's take some time so I would have to plan on the car having some down time. I still think the 5'' is going to be sustainable when it comes to reliability and useability. I know a few people here locally that have the 5'' and they have basically the same mods as I do and they all said you will see a major change in your IAT temps from the stock intercooler. also more flow which is a good thing too.
04-02-2012, 08:37 AM | #20 | |
Rep 2,898
Neil |
04-02-2012, 11:38 AM | #21 | |
Rep 54
04-02-2012, 12:12 PM | #22 |
Rep 1,283
The Helix has incredible ait control and has been pushed over 600hp. You can install it by simply removing the belly pan, using ramps and requires NO cutting or trimming on a 335i and only very minor trimming on a 135i. Its truly a get it and forget it mod and if you decide to sell your car in the future the Helix holds its value we'll selling for $600+ used...We are currently running our spring group buy for the Helix FMIC:
http://www.e90post.com/forums/showthread.php?t=665777 |
