Procede REV 3 help please
03-30-2012, 07:56 PM | #1 |
Rep 88
I just went to Vishnu yesterday and exchanged my Procede for a Rev 3 version with NLS and 2 step enabled.
My problem is after installing it my car kept getting a half engine light and cut power ( to the point were i almost didn't make it up a hill in San Francisco) Shutting the engine off then turning it back on again lets me drive again, But as soon as i try to make any power the same thing happens. When I got home i connected the laptop to see if there was any fault codes, 12140 and 11900 the 11900 i could not find what that was. Now my problem is while trying to figure out what map was installed ( Robert told me he put in 11-25 map) I did something that i believe loaded a different map (even though I did not select open file) and now the car will not drive and is stumbling at idle. It has a procede error code of 7 which is for incompatible map or firmware. Trying to download the zip file 11-25 and extract it is giving me an error. Can someone please send me the unzipped 11-25 6MT bin file. Thanks everyone for all there help. |
03-30-2012, 08:58 PM | #2 |
Rep 4,771
Did you exchange the harness as well?
Because if so, a bent pin or some other type of installation error might be the cause. I had the same thing happen and when I uninstalled the harness, I noticed a pin was bent into another pin. Straightening that out and reinstalling fixed the problem. |
03-30-2012, 09:34 PM | #3 |
Rep 81
I just got my rev 3 with NLS and 2step and the car won't drive and barely runs, hooked it up to the lap top and there was no map at all, procede is apparently a dud, I have a new one in the mail hopefully that will fix my problem.
03-30-2012, 10:35 PM | #5 |
Rep 88
I'm using a pc, but yes the code 12140 is the exhaust flap so no worries there.
I got the correct map loaded again 11-25 but two step is still not working, not sure about the half engine light because I didn't get a chance to test drive. And I do have the latest harness. |
