JB4 on the IS
03-30-2012, 09:53 AM | #1 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
JB4 on the IS
They just released IS specific firmware for the JB4. It boosts PSI in the middle ranges over the current firmware & also changes the AFR to better support this version on the N54. Also good for the sport car & 1M.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-30-2012, 01:21 PM | #2 |
Rep 2,856
Drives: 2011 335is E93
That's good to know. I plan on grabbing an 11is because I don't like the F30's lol...I'll stick to the E90's
03-30-2012, 02:07 PM | #3 |
Higher than you
Rep 294
Hmmm... Was set on Cobb, but this has my interest piqued.
Current: '15 M235iX | '15 Macan S | '00 Honda S2000 Notable Previous: '12 E92 335is | '10 STi | '88 E30 325iX |
03-30-2012, 02:41 PM | #4 |
Rep 1,358
The engine in the IS models and 1M is identical to every other n54 with the exception of a bit better cooling so why would there be a different set of firmware?
Since most n54 guys running software have added the additional cooling components anyway it seems like once you add software it shouldn't matter what badge is on the back of the car. |
03-30-2012, 02:46 PM | #5 |
Rep 823
?? where do you see "IS" specific software.. this doesn't make any sense to me.
03-30-2012, 02:53 PM | #6 |
3129
Rep 5,264
Two things, first the IS has a different factory timing profile then the stock N54 so boost limits can be set more aggressively on the JB4 IS running 93 octane.
Second the word is "firmware" not software, two different things. The 3/7 interface now has a drop down menu to choose N55, N54 & N54 IS. The user definied settings for All AFR are totally different then the stock N54
Kevin
03-30-2012, 03:02 PM | #7 |
Rep 799
Drives: 08 335 silverback
its not firmware that was "just released" it is the new interface that has a model specific option, for model specific options(gauges etc.)
FBO...METH...BIG TWINS
03-30-2012, 03:05 PM | #8 |
Rep 823
Nevermind.. I see this though I am curious as to what the impact is.. I get it for tune only cars.. but FBO cars??
I don't understand why AFR ratios would be touched or why the IS would be "boosting psi in the mid range"... I can understand minor adjustments, but impacts to afr and where the car is boosting?? Please provide actual differences in the adjustments if you have them.. thanks |
03-30-2012, 03:08 PM | #9 | |
Rep 823
03-30-2012, 03:09 PM | #10 |
Rep 823
03-30-2012, 03:09 PM | #11 |
3129
Rep 5,264
The AFR all settings are now totally different between with the new & old versions where they were the same for both models.
To me getting more boost up the middle of the RPM range is new to me no matter how you want to parse the words.
Kevin
03-30-2012, 03:17 PM | #12 | |
Rep 823
Interesting it seems like peak boost hits earlier and drops earlier now for the IS. |
03-30-2012, 03:17 PM | #13 |
3129
Rep 5,264
Yes tune only waiting for the Brown Truck to drop off an FMIC but that will be my only mod. Just looking for a slight edge over other IS cars
IS Map 6 no bolt-ons 15psi from 2500 to 5000rpm Stock Map 6 15psi from 5000 to 5500rpm. All other RPM steps have higher boost across the board for the IS starting at 1500 rpm where its 13psi vs. 10psi
Kevin
03-30-2012, 03:43 PM | #14 |
Joint Chiefs of Staff
4918
Rep 115,980
BMS is working on even more 1M/335is specific changes. A lot more in the pipeline for you guys. But the new 1M/335is map 6 is a beast!
Mike |
