The Dreadful Cobb Codes
03-29-2012, 08:31 AM | #1 |
Rep 1,356
A while ago I was driving and my car's check engine light came on.
Turned it off and went away, never worried about it. Today - took the cobb out to take to the dealership for some work and I checked engine codes and got the following So help help help P30FC H30FF H30FC H2D25 |
03-29-2012, 08:44 AM | #2 |
Rep 7,377
if you unistall cobb it clears the codes so those must have come up after that. Anyway seems you have a leak somewhere. lots of threads if you search up the codes.
Which map were you running?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-29-2012, 09:42 AM | #4 |
Rep 554
Drives: E92 335i 6MT
I've never been able to find information on the codes that begin with H. Google doesn't turn up anything.
H30FF H30FC H2D25 Does anyone know what they mean? |
03-29-2012, 10:03 AM | #6 |
Rep 7,377
Remove the first letter and search the codes in here.
Again which map were you running? V301, V400?
03-29-2012, 10:04 AM | #7 | |
Rep 260
You must be running old firmware since 2D25 is being suppressed with more recent firmware releases.
Stage 123| DCI | ETS FMIC
03-29-2012, 10:11 AM | #8 |
Rep 554
Ahh, thanks enrita, gboop, didn't know that. They aren't on mine now but I remember pulling similar codes up on older firmware, haven't checked since the beta updates.
03-29-2012, 10:20 AM | #9 |
Rep 1,356
so those codes are normal? I think I was under v301 I just downloaded Stage 2 maps. After the dealership visit, I am going to install the DP's and than install stage 2
03-29-2012, 10:40 AM | #10 |
Rep 2,197
Upgrade to the V401 firmware(make sure you have the latest AP manager downloaded first) and run that. Those codes are normal and it's just a matter of chance if you trigger them IIRC. The 30FF is a boost leak code, so you MAY have a boost leak but some people see it without actually having a problem.
Log req boost, actual boost, WGDC both banks and if you have a leak your WGDC will try to compensate for it and you'll be able to see it. |
03-29-2012, 11:22 AM | #11 |
Rep 1,356
Rader1, i know this may be a stupid question but on the COBB how do I log those things. I have tried in the past to log but I think I was not doing it correctly
03-29-2012, 12:32 PM | #12 | |
Rep 2,197
Plug your AP into the car and select monitor->set data log list-> and then scroll through the list and x out the channels you want to log.(I do boost, rpm, lambda bank 1&2, timing cyl 1&2, charge air temp, TPS actual, WGDC bank 1&2, load requested and actual load) Find a SAFE place where you can do a 2nd-3rd gear pull and then select monitor-> data log-> and click the center button right before you go WOT. It will save the file as a .csv and you transfer it to your computer. You can graph it using excel or virtual dyno( http://www.bradbarnhill.com/projects/VirtualDyno/ ) Then post up your logs and people will help you to read and understand them. Hope this helps!!! |
