New Turbos installed.
03-27-2012, 11:27 PM | #1 |
Rep 503
Drives: 2016 328dX Msport Estoril Blue
So dealer replaced both turbos and pretty much everything else under warranty.
How do I maintain the turbo's and keep them in good shape for the next upcoming years? Do I need to let the car sit for 2-5 minutes everytime I drive it before shutting it off? Or is there an electric cooler that kicks in after the car is shut off everytime? What is good measure to practice with our N54's? |
03-27-2012, 11:32 PM | #2 |
Rep 2,626
is your car stock? if it is, then its hard to toast your turbos
the electric water pump does a good job of cooling the turbos after you turn the engine off. However, after a spirited run , I always let it cool down for a couple of minutes.
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-27-2012, 11:43 PM | #3 |
Rep 2,197
There's not a whole lot you can do to guarantee long life for your turbos. Let the car idle for atleast 30 seconds after a run and wait for oil to reach operating temp before pushing it hard. Other than that, just be sure to do the required maintenance at the recommended times.
Except the oil changes, DO NOT do the 15K mile oil change interval. Do it every 5K or less(but thats's just my opinion.) |
03-27-2012, 11:46 PM | #4 | |
Rep 2,558
Also, what was the reason for replacing your turbos? Failure? Or just wastegate rattle?
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
03-27-2012, 11:56 PM | #5 |
Rep 503
Thanks guys! thats good advice... you know how a lot of the previous Turbo tuning guys in Audi's and Supra's and Subaru's use turbo timers... I wondered if that rule of thumb applied to us too.
I am bone stock for now. I had a misfire that was occurring, and my dealer being the great guys that they are, replaced every little thing that could have caused a misfire, poor fuel mileage, and weak acceleration. The turbo's actually did fail... also had the walnut cleaning done... and every other part you can think of replaced to rule out other variables. Turns out it was a plugged cat! Now the car is running flawless (so strong and fast), and I'm so happy so far. So time to start some baseline dyno's and see where its at. |
03-28-2012, 12:03 AM | #6 | |
Rep 2,558
03-28-2012, 12:24 AM | #9 |
Rep 2,013
New turbos, give them 500 miles of break in, so no wot.
Whwn you start the car, never get on boost until the oil is warmed up, when tou drive aggresively let the car idle 1-2 minutes before shutting it off. Do regular oil changes and youre set! |
03-28-2012, 12:26 AM | #10 | ||
Rep 2,013
Its much better to leave it on and let idle for a minute or two. |
03-28-2012, 12:43 AM | #13 |
Rep 2,558
Where did you get this information? Why would the oil not flow like it would when the engine is running? Not trying to be aggressive or anything, but I've never heard that before and would like to read more about it. Thanks!
03-28-2012, 12:50 AM | #14 |
Rep 503
03-28-2012, 12:54 AM | #15 | |
Rep 2,013
Im 99% sure that oil doesnt circulate through the turbo once the engine is off, if im wrong someone please correct me. |
03-28-2012, 01:05 AM | #16 |
Rep 3,456
Drives: Harrop E90 M3
You are correct. The oil pump is mechanical and driven by the crankshaft. So if the engine is off, obviously there is no oil flow short of gravity draining residual oil into the pan. The N54 as well as all other NG6 BMW engines use an electric water pump only. No belt driven units any more. It will run as needed to cool the engine, not necessarily just the turbos.
03-28-2012, 01:12 AM | #17 | |
Rep 2,013
Op, as long as you let it idle 1-2 minutes theres no problems. |
03-28-2012, 01:13 AM | #18 |
Rep 503
Electric waterpumps mean lower failure rates? they don't need to be replaced as good measure when doing higher mileage services?
03-28-2012, 02:24 AM | #19 |
Rep 3,456
It's done more for efficiency. It's part of how BMW reduces parasitic power loss, while increasing power delivery to the wheels as well as fuel economy while lowering emissions. Since that's what the world is all about. It's a pretty complex water pump in terms of logic, control and monitoring. If there's a problem, the car won't hesitate to let you know. Warnings in the cluster and auxiliary fan on high speed are usually a dead give away that it's a water pump and/or thermostat.
03-28-2012, 03:54 AM | #21 | |
Rep 1,809
But obviously if you run stock the turbos will last longer. Last edited by tscdennab; 03-28-2012 at 04:16 AM.. |
03-28-2012, 10:20 AM | #22 | |||
Rep 2,626
just to make it clearer, the images below are from realoem. one shows the oil pump and the other shows the oil pump drive which is obviously mechanical.
