Fault codes need help....
03-27-2012, 02:02 PM | #1 |
Rep 49
Hey guys..
Just got my 335xi back from the dealer. They replaced 3 injectors, HPFP, thermostat, and DME from what they said. Anyways i get it back and I'm concerned because I still had my Cobb Accessport installed. Car runs great no problems or error codes. I would imagine if they replaced the faulty DME with a new one my tune would be gone as well.... My tune is still programmed in however. On top of that I pulled error codes H2F81, H2EE0, H2F84, H2F83. Does anyone know what these are and what they mean? Thanks. |
03-27-2012, 03:24 PM | #2 |
Rep 7,377
Well if cobb is still installed it means they did not replace the dme or flash it with new software.
For the codes search them up. U 100% sure you are running a tuned cobb map?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-27-2012, 04:12 PM | #3 |
Rep 49
That's exactly what I thought as well although my receipt states otherwise.
When I plug the Cobb in and view current map it shows up. I tried searching those codes and I didn't come up with anything. |
03-27-2012, 04:14 PM | #4 |
Rep 2,626
Did you go to teh dealership for teh injector recall? they do flash the DME with the latest software. But they shouldn't be able to
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
