New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      03-26-2012, 06:56 PM   #1
DanMiami
Drives: 2013 Z4 35is-M & 2011 335d
2011 BMW Z4  [7.00]
2011 E89 noise from rear axle
Sorry of this is a repeat post, but there is no "search" function on the iPhone app and the search forum function in mobile safari does not work.
Has anyone experiences a loud "clunking" noise - a single clunk - when turning or backing into a driveway or parking space?
There is nothing that I can do which will trigger the noise, it is quite random and sounds like something is falling apart back there. It does not have to be a high speed turn or backing - just normal driving.
It's a 2011, 35, M package, 7 speed, yada yada...
      03-26-2012, 10:25 PM   #2
STOOF
Sunburned
STOOF's Avatar
Drives: '16 F83 M4 Convertible 6MT
2013 BMW 535i  [0.00]
yeah, i have a large speed bump right next to my driveway, so when i pull out in the morning i get that clunk, figured it was cause the car was twisting over the speed bump
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired
2011 Z4 SDrive35i 6MT- Retired
      03-27-2012, 01:24 AM   #3
SHADOW4
SHADOW4's Avatar
Sweden
44
Drives: Tanzanite M4 2018
2010 E89 35i  [0.00]
stupid clunk when acc hard from low speed. happend twice. scares the zhit out of me...........
SA. says nothing wrong. probably the rear axel have to loose some parts before they agree something is wrong.....
i bought my car new at the biggest dealer here and have had some issues with the car. wastegate rattles when warm, 3 mechanics says: should not sound like that. They had the car for a week to fix it. when i was to pick it up it still ratteled. But now it "should" sound like that! I asked for a BT retrofit, SA says it is impossible. With help from a nice German guy i got hold of BMW instructions of how to retrofit BT. - can i have that?, said the Service Manager
with my options the retrofit takes 1 1/2 hour including everything and they would charge me 3300$, parts cost less than 650$. I think i will do it myself next winter"...
Sorry for hijacking
      03-27-2012, 10:27 AM   #4
DanMiami
2011 BMW Z4  [7.00]
This cannot be normal...
We pay good money for these things - they shouldn't sound like beat up pintos!
      03-27-2012, 11:07 AM   #5
DavidJS
Drives: Z4 sDrive 35is
How did you find that out, Dan?
      03-27-2012, 02:52 PM   #6
DavidJS
Good to have connections!
      03-27-2012, 10:18 PM   #7
t612
t612's Avatar
Drives: '19 X3 M40
I got my 2011 Z4 last June and noticed a clunking noise from the rear in July - similar to what you described. Brought it into my dealership. They kept it for several days and found it to be a bad wheel bearing and hub. They replaced the bad part and re-aligned the wheels. Everything has been fine since. My dealer was really persistent in getting to the bottom of the problem; otherwise, I would have had to keep bringing it back. Hope this helps.
      03-28-2012, 09:16 AM   #8
DanMiami
2011 BMW Z4  [7.00]
Thanks for that... Going to text my service advisor now!
      03-31-2012, 08:59 AM   #9
t612
t612's Avatar
Drives: '19 X3 M40
Sure thing. Glad I can help. Let me know how if turns out after working with your dealer.
2019 X3 M40
2014 MINI Cooper S Hardtop
2010 535i xDrive
2005 Yamaha R6
      03-31-2012, 06:07 PM   #10
Desmo85
Desmo85's Avatar
83
Drives: E60 / E87 / E89
Damn got the same noise on mine too! It comes from the right backwheel and it occours when I take right turns (angle 90° +)
When I dropped it off they said they could not find anything
      04-01-2012, 09:09 AM   #11
Desmo85
Desmo85's Avatar
83
I did some research and found a lead to something that could fix it:
In a german Z-forum (zroadster.com) I found a thread about the same issue!
One of the ways to get rid of it they say is getting the rear stabilizers replaced, but before that they may should check the pre-stress- tension on the stabilizers.
I ll drop mine off next week lets see if they can fix it.
      04-27-2012, 11:39 AM   #12
DanMiami
2011 BMW Z4  [7.00]
So... did you have success with this?
      04-27-2012, 11:41 AM   #13
DanMiami
2011 BMW Z4  [7.00]
Did you do anything about it?
      04-29-2012, 03:46 AM   #14
Gunzaro
Cyprus
37
Drives: Speed Racer
I also have a clunk or 'twang' sound when I back out of my steep driveway and turn at the same time or if I go forwards driving in. Also when going left around a particular corner which has a slight bump in it; with the right side loaded the left makes a clunking noise.
I assumed it was 'normal' because I do not feel any degradation of performance etc. Only those two particular times.
      04-29-2012, 02:09 PM   #15
stickshifter69
My symptoms are exactly same as yours. But I never brought it in since I thought it could be normal.
      04-30-2012, 01:03 AM   #16
wdlfbio
Drives: 2013 4S, 2015 3500 HD Dually,
Why on earth would any "clunking" on a $60k+ car be ok??? Isn't the sound of metal hitting metal a bad sign? If ours ends up doing this, I will be very vocal and persistent with BMW.
'16 235i
'15 3500 HD Dually
'13 C4S
      05-02-2012, 02:24 PM   #17
z4z4z4
z4z4z4's Avatar
Drives: 2002 M3
Sounds like a binding rear sway bar mount needs a little lube.
Sold 2011 Z4, kept 2002 M3
PM for various e89 parts 4sale.
      05-03-2012, 07:58 AM   #18
Alext
Drives: B M W
Would silicon spray be ok to lubricate them?
      05-03-2012, 10:24 PM   #19
z4z4z4
z4z4z4's Avatar
Drives: 2002 M3
Can't speak from experience. My aftermarket purchases came with lube impregnated design.
Pick your poison from a search on Google.
http://grassrootsmotorsports.com/for...e/21213/page1/
      05-29-2012, 02:18 AM   #20
Gunzaro
Cyprus
37
Drives: Speed Racer
Had the dealer investigate. Everything was OK. The dealer said it was the pad moving in the caliper. But why would this occur over bumps?
EDIT: Clunk is still present. Happens when doing a U-Turn. But cannot reproduce all the time - very intermittent.
      05-30-2012, 12:38 PM   #21
DanMiami
2011 BMW Z4  [7.00]
Mine is in the shop still... they are working on it... ordered new parts from Germany... I want my car back!
      05-30-2012, 04:59 PM   #22
Gunzaro
Cyprus
37
Drives: Speed Racer
Update us when you find out what parts or what was done to your car please!
zpost
