E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > How to launch an AT?
      03-23-2012, 02:17 PM   #1
triggz
Drives: E92 335i
Hey guys,
Just curious as I am hitting up the 1/4 mile soon for the first time.
My buddy just got a 2012 C63 Coupe Performance Pack and he wants to run me on the strip.
I understand you have to brake-boost in 2nd gear up to 2000rpm.
My question is, do you use the kickdown feature or not?
I find the car feels faster when I use the kickdown off a roll. For example being in 4th gear and using the kickdown usually puts me in either 2-3 and the rpms jump real fast. However, when I just floor it (before the kickdown) in 3rd, it doesn't have that instant "jump" effect, as it's more of a buildup.
Please advise,
Thanks
      03-23-2012, 02:31 PM   #2
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Originally Posted by triggz View Post
Hey guys,
Please advise,
Thanks
I'm no pro but I don't use the Kickdown. Need to modulate throttle a bit off the line on street tires.
E90 LCI N54 6AT
      03-23-2012, 02:39 PM   #3
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
Kickdown in that situation would be a bad thing. I'm guessing you can't get traction in first gear at all if you don't have an LSD and decent tires. Yes brake boosting in second gear is a good idea but even at 2,000 RPM you may spin...as it all depends on the track prep. If it's real sticky, you may be ok.
And let us know what you do and how it works out. We're all hoping you can take the C63
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      03-23-2012, 02:40 PM   #4
dlbrooks18
dlbrooks18's Avatar
161
Drives: e90 335i
Nice mods you have.. yeah you can put it in 2nd and brake boost to about 2-2500 and ease in to it and shift your self or just put in DS and brake boost the same.. as stated above modulate the throttle a bit on launch then get your foot in it.. report back and let us know how you do!
2008 E90 335
      03-23-2012, 02:59 PM   #5
idrift4wd
Drives: Three Hundred and Thirty Five
2007 BMW  [7.00]
with your set-up. Brake torque 2nd (2k-3k)build a little boost. press the peddle all the way down WITHOUT pressing kickdown button. Wait until around 40-50 stomp gas, pressing the kickdown button. (it will keep in second gear and switch to third by it self.) But you can pick your shift point, people say around 6200 rpm, but some just let it run to redline
trick is not to downshift to first. If your going less then 30-35 its going to shift down to first from a 2nd gear launch. Or if your tires are stickier enough, 1st gear brakeboost, floor it with kickdown.
      03-23-2012, 03:31 PM   #6
iBoost
Retired e90post Member
iBoost's Avatar
135
Drives: real slow
If you brake boost in second and try to use the kick-down right away you'll have a really slow launch. The car will downshift to 1st.. Brake boost to about 2k and then keep the pedal right before the kick-down.. Good luck on the run!
      03-23-2012, 03:38 PM   #7
triggz
Drives: E92 335i
Thanks for your help guys!
I will report back with the results and hopefully some video footage
He literally just picked up the ride a few weeks ago and he mentioned it comes stock with LSD.
My tires are Hankook V12 Evo (from what ive heard they arent the greatest from a dig)
      03-23-2012, 03:42 PM   #8
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Yes, your tires are total garbage. Sorry to say but true.
E90 LCI N54 6AT
      03-23-2012, 03:43 PM   #9
triggz
Drives: E92 335i
*sigh* I know. I'm waiting for them to be done so I can grab a set of Nittos.
      03-23-2012, 04:08 PM   #10
cupertinosteve
Drives: BMW 335i
FYI - the kickdown won't happen when you're over 4800 RPM. Its not based on the speed you're driving but the RPMs you're at (test it on the highway).
      03-23-2012, 04:12 PM   #11
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
I've accidentally hit the kick down at the track short shifting the 3-4 at 6200 RPM and ruined runs before.
E90 LCI N54 6AT
      03-23-2012, 04:13 PM   #12
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
If he has a p31 he will likely outtrap you a little bit. Lucky you can launch in 2nd though.... He can't so he may spin badly.
E90 LCI N54 6AT
      03-23-2012, 04:18 PM   #13
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
Brakeboost 2500-3000 rpm m2
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      03-23-2012, 05:09 PM   #14
Stucks
Stucks's Avatar
Drives: 2017 F30 340i Xdrive
NT05's hook pretty well. They are one of the closest things you can get that are like a drag radial, but still classified as a street tire.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost.
Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold)
      03-23-2012, 05:16 PM   #15
RnmEvo9
Drives: 2007 335i
How are you guys brake boosting in 2nd up to 2500 and not spinning? I need to modulate the throttle off idle in 2nd gear to get any decent traction. I am using RFT's though, so that may be the culprit even though they are practically new.
      03-23-2012, 05:26 PM   #16
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
RFT suck! I had issues with them even on stock map! and they were practically new. They just can't take the beating. I love my nitto's!
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
e90post
