vanguard exhaust rubbing the chassis brace.
03-23-2012, 10:08 AM | #1 |
Rep 2,007
had the vanguard exhaust installed and the shop told me i needed bigger separators for the chassis brace since the exhaust didnt clear the brace even with the separators supplied by vanguard.
any thoughts/solutions??????? |
03-23-2012, 10:12 AM | #2 |
Rep 2,875
put some more washers under the cross brace bolts to create more clearance.....I had to add 2 extra washers.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
03-23-2012, 10:22 AM | #3 |
Rep 2,007
03-23-2012, 10:33 AM | #4 |
Rep 2,875
I didn't neet longer bolts for the 2 extra washers, it's like 2mm for both washers. I added the washers in addition to the spacers provided by Vanguard.....No biggie.
03-23-2012, 11:18 AM | #5 |
Rep 2,007
03-23-2012, 11:27 AM | #6 |
Rep 28,154
i've had to get longers bolts a few times, its either variances in the cars or with vanguard, one car will not need even the supplied spacers at all, and another will need the spacers and 2-5 washers to have the clearance.
remember it IS a chassis brace, so only getting one or two threads threaded in after adding the washers is not acceptable. match up longer bolts if needed |
03-23-2012, 12:42 PM | #7 | |
Rep 2,007
must be a vanguard thing cause i doubt all e90/e92 are different when it comes to exhaust fitment. sucks |
03-23-2012, 01:47 PM | #8 | |
Rep 1,261
I started with 4 washers were it was hitting down to 3 then 2 and 1 to make the transition nice. Also i have plenty of threads left when installing without even getting longer bolts, you should be perfectly fine. Get under there is do it yourself you will see its so easy. |
03-23-2012, 02:29 PM | #9 | |
Rep 2,007
03-24-2012, 08:53 AM | #10 |
she likes the flavor......
85
Rep 1,622
OP I had the same issue with mine....fixing it makes it sound much better than having it touch that brace.
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
03-24-2012, 08:57 AM | #11 |
Sameet
739
Rep 2,541
Drives: AY/B M4 '15
When I had MAC install my Vanguards, they made custom flanges to extend the pipes as to not hit the xfer case..I didn't like it one but cos in reverse, my car would constantly vibrate.
I had a shop remove the flanges and mandrel bent the midpipe that would rub against the xfer case. No issues at all anymore! |
03-24-2012, 09:04 AM | #12 |
Rep 2,007
03-24-2012, 09:04 AM | #13 |
Rep 2,007
03-24-2012, 12:25 PM | #17 |
85
Rep 1,622
mine was just barely touching so i took it off and gave it a couple of taps with a hammer, nothing crazy
03-24-2012, 12:51 PM | #18 |
Rep 2,007
mine is touching a lot to the point where is being pushed up by the chassis brace even with the plastic grommets on, so i probably just need to add separation between the brace and exhaust.
