Lost Boost
03-22-2012, 08:32 PM | #1 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Lost Boost
I lost boost today. I looked under the hood and saw this.
Before getting on the highway I pressed the throttle and I felt like the car bucked(hesitated) and then I had no boost. Car feels like a Nissan Altima 2.5 Is this the reason? If so, how do I put it back? Car is hot right now so I'll tackle this in the morning. How did this happened? |
03-22-2012, 08:37 PM | #3 |
Rep 2,663
Thanks. How you think this happened?
03-22-2012, 08:39 PM | #4 |
Rep 6,631
It's actually pretty common. Just take the top DCI cone off and pop it back on you'll be ok.
E90 LCI N54 6AT
03-22-2012, 09:00 PM | #7 |
Rep 2,663
Damn...
Thanks guys |
03-22-2012, 09:05 PM | #9 |
Rep 2,663
03-22-2012, 09:20 PM | #10 |
need4speed
510
Rep 1,903
Check out this link for an after market CP. I personally think this is one of the best CP's because they have two styles as u will c (for pre-lci's and lci's).
http://www.evolutionracewerks.com/node/53
N54
03-22-2012, 09:22 PM | #11 |
Rep 5,175
03-22-2012, 09:32 PM | #13 |
Rep 2,663
Thanks I'll look into those alternatives..
03-23-2012, 10:38 AM | #14 |
Rep 2,875
The stock CP is fine for the job. I'd say if you're getting in there anyway, just wipe down the inner surface of the CP where it connects to the TB, and make sure the CP is on the TB all the way before installing the C-clip.
That happened to me once, except it was at the CP/FMIC connection, lol. Car made a loud 'pop' noise and freaked me out.....
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
03-23-2012, 10:51 AM | #15 |
Rep 2,172
Haha, I had the same thing happen when I put my new 3" charge pipe on. First time out at 10psi it popped off. I didn't get the clamp secured. More than likely, whoever had the charge pipe off last didn't get it put back on 100% and the wire clip wasn't locked in place correctly. make sure both sides drop into the slot, otherwise it will happen again.
03-23-2012, 11:13 AM | #16 |
Rep 1,809
03-23-2012, 11:15 AM | #17 | |
3441
Rep 79,211
03-23-2012, 12:50 PM | #18 |
need4speed
510
Rep 1,903
Very true. Why spend more money on an elbow plus have to deal with extra parts. Go 2009+ for sure.
N54
03-23-2012, 07:07 PM | #19 |
Rep 2,663
HELP!!!
I'm trying. I'm sliding the CP all the way and then securing the pin. It doesn't do anything. I can slide it right off. What I'm I doing wrong? Is there a youtube video I can watch? |
03-23-2012, 07:20 PM | #20 | |
Rep 277
Quote: Originally Posted by themyst Sucks. Guessing you have an N55? Never heard of the charge pipe breaking on an N54. Blowing off yes, breaking no. factory charge pipe will break off, well... it actually blows off, but it can break the pipe in the C-clip area. ask me how i know... |
03-23-2012, 07:21 PM | #21 | |
3441
Rep 79,211
IF you have some light you can ensure the slots on the TB and CP line up for the c clip. |
03-23-2012, 07:44 PM | #22 | |
Rep 2,663
I had to wiggle it around until I heard the metal clip, clip in. Thanks a million!!!
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
