Oil Filter Housing Gasket Leak??
03-21-2012, 04:42 PM | #2 |
Rep 464
sure does! mine looks similar but not as bad yet lol changing it out this weekend as well as changing coolant also..good luck the gasket is like $11 online
Current car- 2003 cobra S/C stockish
* previous cars 2007 335i e90 Jb4, downpipes, intake, magnaflow exhaust, 375+whp 2005 SRT4 big turbo built to hell.. 420+WHP in a 2700 pound car! |
03-21-2012, 05:15 PM | #4 | |
Rep 2,626
mine is beginning to show signs of wear (@ 75k now)
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-21-2012, 05:26 PM | #5 |
Rep 464
ya if u have awarranty it should be covered...i have extended warranty but instead of paying my $100 deductable i figured id do it myself and save $85 lol plus im not doing anything this weekend
03-21-2012, 07:13 PM | #6 |
Rep 82
I am going to dive into it this weekend. I picked up the gaskets today, I am going to knock out the valve cover gasket as well, depending on how the oil filter housing gasket replacement goes.
When I bought the gasket for the oil filter housing, the guy told me that there is another gasket that is usually replaced at the same time. I didnt see that mentioned in any of the DIYs. I'm sure ill figure out where it goes though. Heres a pic of all the gaskets and part numbers for reference. |
03-21-2012, 07:28 PM | #7 |
Rep 3,456
Drives: Harrop E90 M3
It requires the second gasket if you have an oil cooler. Also you should replace the o rings on the lines going into the housing as well, if you have an oil cooler
03-21-2012, 08:24 PM | #8 |
Rep 464
[QUOTE=Bmw135er;11594619]It requires the second gasket if you have an oil cooler. Also you should replace the o rings on the lines going into the housing as well, if you have an oil cooler[/QUOTE
you dont have to take off those lines do you? i have an oil cooler and no one mentioned anything to me about replacing that gasket. Im not replacing the intake manifold gasket either...if i think it need to be replaced ill replace it in a few weeks when i clean my valves and do spark plugs...any tips???? the part# ending in 335 i dont believe you need to change when you have the housing leak unless thats whats leaking, i could be wrong tho
* previous cars 2007 335i e90 Jb4, downpipes, intake, magnaflow exhaust, 375+whp 2005 SRT4 big turbo built to hell.. 420+WHP in a 2700 pound car! Last edited by jayk877; 03-21-2012 at 08:32 PM.. |
03-21-2012, 10:01 PM | #9 | |
Rep 82
I didnt know about the o-rings needing to be replaced. I was really trying to avoid having to go back to the dealership again. Do you really think that is important to change? I guess if I need to go back, I can pick up spark plugs and cabin filter and swap those out while I'm at it. |
03-21-2012, 10:50 PM | #10 |
Rep 2,291
This post popped up at a good time. My gasket began leaking a couple of days ago. I'm going to be making a parts run to the stealership tomorrow. Im hoping I can knock this out in a couple of hours of work.
03-22-2012, 12:12 AM | #11 |
Rep 2,626
I bought everything off ECStuning... their prices are lower than the dealership if you're not in a hurry
03-22-2012, 06:08 AM | #12 |
Rep 656
I would replace the bolts that you remove from the oil filter area, but others have debated that. I replaced them when I upgraded my housing to the one with oil cooler provisions.
03-22-2012, 06:45 AM | #13 |
Rep 464
So does the oil cooler gasket have to be replaced if its not leaking? Also what about the intake manifold?
03-22-2012, 07:56 AM | #14 |
Rep 2,291
Thanks, but I'm in a hurry. My serpentine belt needs to be replaced also. Its about 1/2 the width that it should be. I'm wondering if some oil got on the belt and caused it to be more brittle.
03-22-2012, 08:12 AM | #15 |
Rep 464
Does anyone have a part # for the o rings that need to be replaced?
03-22-2012, 09:19 AM | #17 |
Rep 464
How much you pay to have it done? Shouldn't the o rings come with the new intake manifold gasket? Shouldn't be too bad I mean I installed my own downpipes so it cant be worse than that lol I have a warranty but don't wanna bring it in for something this small bc is have to take downpipes off and take jb4 out...so ill give it a shit first lol
03-22-2012, 11:23 AM | #19 |
Rep 27
Hey secretsquirlrel
BIG FYI on serpentine belt. You must do a search on serpentine belt ASAP on this e90 post and N54tech post You will see my curent issue and many others regarding serpentine belt problem. The may be a new recall comming very soon regarding subframe assemble and belt failures on early 3 series. |
03-22-2012, 12:06 PM | #20 | |
Rep 2,291
Hmm, interesting. My car has 07 has 70k on it, so I'm hoping its not related to the issue you are having. The belt has never been replaced, so i'm hoping it just a maintenance need. |
03-23-2012, 01:22 PM | #21 | |
Rep 656
03-23-2012, 01:24 PM | #22 | |
Rep 656
You have to lift the intake manifold, but I didn't have to/couldn't remove it completely. |
