No Sound Coming From Left Side.....
03-20-2012, 04:15 PM | #1 |
Rep 90
Searched but didn't find exact issue.
This morning I started my car and all speakers were working. Drove about 100 yards and all speakers on the left side cut out. Switched from Satellite to Terrestrial radio same thing. Turned the volume up higher and the left side came back on and has been working fine since. I have the Hifi, non-logic system in an '08 E90. Anything I should be concerned about or anomaly. Is the start of a failing amp? Thanks |
03-22-2012, 05:53 PM | #2 |
Rep 90
No responses but I will document here until I resolve it.
Because of all the pollen I have washed my car twice this week. A couple hours after washing the car yesterday the sound cut out again on the left side. I turned up the volume and there was some static but it cleared and both sides were fine. It has been fine all day today with multiple trips and turning on and off. The morning it cut out a couple of days ago I washed it the night before. Is there something that could be getting wet and causing the problem? |
03-22-2012, 06:12 PM | #3 |
Rep 13,104
you could check the amplifier for wetness.
Its in the driver side rear fender area . In mine its under the plastic tool
kit area between the wheel well and rear fender. Its the same position for all e9x if it has and amp Hi Fi or L7. |
03-22-2012, 07:05 PM | #4 |
Rep 90
So you think it is the amp starting to go as well? I was thinking about doing one of VP Electricity's basic upgrades. Just do not want to pay a dealership a bunch of money to diagnose the problem when it could go towards upgrades. Also, wanted to see if anyone else has had same problem/symptoms.
03-22-2012, 08:19 PM | #5 |
Rep 13,104
You said you washed it .
So I thought you were looking for shorts in areas that water could theoretically get into. I have a VP system its really nice, magnitudes better than stock .
03-22-2012, 08:30 PM | #6 | |
Rep 90
As for VP's setups I will probably get the Jehnert subs, JL 600 6 and do the install myself..... IF, this amp does quit working on me. Just hope it is not the head unit. |
