N2O TMAP sensor for JB4!
03-20-2012, 03:21 PM | #1 | |
Joint Chiefs of Staff
4918
Rep 115,980
Little update for JB4 owners who plan to run large turbos, or really anyone who wants a simple PNP adapter for the N2O 3.5 bar TMAP sensor.
03-20-2012, 03:28 PM | #2 |
Rep 3,730
Well I know someone who has my RB's and a JB4 that wants to do this. Mentioned it to him last week about the N20 sensor, so do you need to customize his JB4 maps?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
03-20-2012, 03:31 PM | #4 |
Rep 3,730
Yea you can now go past 21-22 psi. I'm guessing they can hold up to 25 psi before they start maxing out.
03-20-2012, 03:35 PM | #5 |
Rep 6,631
They can go north in the 5000-6000 range, however it seems even RBs are tapped at redline around 19-20 psi.
E90 LCI N54 6AT
03-20-2012, 03:37 PM | #6 |
Rep 2,291
What sort of HP/TQ benefit?
2jZ + RB26 + 4G63 + LS9 + N54 =
03-20-2012, 03:38 PM | #7 |
Rep 3,730
It's worth a try. Crank them up in the mid range and taper off to about 19 psi at the top. They are size limited so I do agree I don't see them pushing much more than stock, but at least there is room to work with. Testing will be done soon enough.
03-20-2012, 03:40 PM | #8 |
Rep 6,631
I don't have RBs yet and no one has tested this yet. I'm sure whn the info becomes public we will all know.
E90 LCI N54 6AT
03-20-2012, 03:47 PM | #9 |
Rep 3,730
Assuming the RB's are not already tapped out at 21 PSI, there will be increased performance when more boost is added. I'm sure Rob has done some flow testing on these, maybe he can chime in on how much more boost they can hold. Keep in mind, these are still TD04 housings, so you won't see the huge numbers of a large single.
03-20-2012, 04:01 PM | #10 | |
Rep 6,631
E90 LCI N54 6AT
03-20-2012, 05:52 PM | #11 |
Rep 4,764
That's the key, the stock housings, exhaust manifold, and the stock intake piping.
I'm extremely happy with RB's as is, if we can squeeze out another 25whp on meth + 93 pump I would be overjoyed. |
