Torque wrench for our cars
03-20-2012, 12:11 PM | #1 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
COBB uses a nice torque wrench in the video to install spark plugs. Anyone know a place to get a nice digital one for a good price.
This is the one I believe I saw in the video but in gray (Torque Wrench, Electronic, $469.95) |
03-20-2012, 12:18 PM | #2 |
Some dude
92
Rep 1,780
Those are the ones I use. The grey wrenches do angle torque, which is only required for certain fasteners in the engine and suspension. You will need a 3/8" 10-100lb-ft non-angle torque wrench for most all work you will do. Some suspension bolts are 100Nm + 90 degrees, which requires the 20-250lb-ft 1/2" drive. Rod bolts, all of the aluminum bolts, and head bolts are angle torque, so if you're going to do any of those jobs on your own, the 3/8" and 1/2" angle torque wrenches are the ones to have. Just pricey.
They also read inch-pounds and Newton-meters. If you have money to burn, they also make a 1/4" angle torque wrench, which is handy for the smallest aluminum bolts and internal engine bolts. It's good from about 4 up to 20lb-ft.
RRT
E92 335i/6MT with stuff and things |
03-20-2012, 12:24 PM | #3 |
3441
Rep 79,211
Find someone who is in a mechanics school, they usually get 50% off retail (which is cheaper then what the drivers pay for the tools in the truck sometimes).
03-20-2012, 12:28 PM | #4 | |
Rep 2,626
http://www.amazon.com/gp/product/B00...00_i00_details http://www.amazon.com/gp/product/B00...00_i00_details
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-20-2012, 12:30 PM | #5 |
Rep 1,809
I got a Hazet 5121-1 torque wrench for like 80EUR which works between 20-120Nm, so it covers both the spark plugs (24Nm) and wheels (120Nm). It's great !
03-20-2012, 12:31 PM | #6 |
Rep 3,730
Go get a Snap On (electronic) and have it calibrated...$250. I just use the cheaper Craftsman as it gets the job done for what I use it for.
http://www.amazon.com/Snap--Industri...2264606&sr=8-5
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
03-20-2012, 12:34 PM | #7 |
Rep 2,663
@JamesM3M5 I'm looking at a new Snap-On one on eBay for around $220.
--Alarm Settings: 10-100 Ft/Lbs, 60-1200 In/Lbs, 6.8-135 N-m --Guarantee range: 10.-99.5 Ft/Lbs, 120-1195 In/Lbs, 13.5-135N-m @Jeff@topgearsolutions Unfortunate the only friend I know graduated years ago and is not a mechanic no more @marv85 I have one of those I picked up at home depot for $60. Looking for a digital one @ tscdennab Hazet are expensive @Syndicategt That's a 1/4 wrench. Don't we need a 3/8 wrench for plugs and wheels? What you guys think about AC Delco? Is it a good brand and just as good as Snap-On for a good digital torque wrench? |
03-20-2012, 01:20 PM | #8 | |
Rep 2,197
03-20-2012, 01:25 PM | #9 | |
Rep 2,663
Can you also break down what each size covers in our cars. I'm out of warranty so I'm doing a lot of DIY lately and need to get the proper tools for this car. |
03-20-2012, 01:39 PM | #10 | |
Rep 2,197
03-20-2012, 02:04 PM | #12 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Spark plugs are not that complicated. I hand tightened mine using common sense. Don't try to be a Rambo with the wrench...
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
