Do BMW dealer reflash your ECU after putting in new injectors?
03-19-2012, 08:15 AM | #1 |
AC
95
Rep 2,387
Got 6 new injectors installed for my car last week. Do you know if BMW dealers need to reflash the ECU after replacing the old injectors with new injectors?
Car felt a bit sluggish since. Yes, my car's ECU was flashed with a tune before the service.
Your Supreme Leader
03-19-2012, 08:20 AM | #3 |
AC
95
Rep 2,387
Dinan Stage 2. I told them I have the tune and told them not to reflash it.
Your Supreme Leader
03-19-2012, 08:22 AM | #4 |
Rep 1,029
That was probably not relayed to the tech or they had to reflash to the newest firmware. Im not 100% on how the Dinan tune works, but i imagine you can just visit the dealer that did your install and have them re-flash it for you.
03-19-2012, 08:29 AM | #5 |
Rep 7,377
if you cant feel the difference between stock and dinan stage 2 means is pretty weak.
Normally they do Reflash with latest DME software . just get it reflashed by Dinan but i read some posts about people having boost issues with Dinan and BMW latest software.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-19-2012, 08:41 AM | #6 |
441
Rep 18,331
ECU flash is not neccessary but they do it under the recall...Really all they would need to do is code in the injector values. Dinan flash is pretty weak though and very pricey. Alot of people migrate towards the Dinan tune because of their past history with BMW and the other platforms. With the N54, they basically slept through and never got up and missed the train.
03-19-2012, 09:24 AM | #7 | ||
AC
95
Rep 2,387
The dealer probably didn't do the reflash, since they told me they the new injectors can be coded in.
They did say the carbon build up in the engine should be cleaned out since it cause the Fix Lamp Indicator - Engine light to come up. I am going to do a few more WOT this afternoon is see how bad it is. Dinan tune is weaker than the other tunes because it doesn't push the engine and turbo as hard as the other tunes, which means they don't throw as much cell codes as other tunes. This is actually the first time the engine light came on. Quote:
Your Supreme Leader
03-19-2012, 09:27 AM | #8 |
Rep 1,029
03-19-2012, 09:56 AM | #9 |
AC
95
Rep 2,387
The #1 trade-off with turbo-engines since the Formula-1 days back in the mid 80s is always: Power vs. Reliability. Otherwise, people will be pushing out 700hp tunes out in the market already.
Your Supreme Leader
03-19-2012, 10:10 AM | #10 |
Rep 1,029
Reliability can be had by taking the time to properly developing a system with components that compliment each other. Pushing small, innefficienty turbos outside of their efficiency range is not the best way to make power, but one that can be done with some degree of reliability given the safety measures programmed into the DME. Needless to say, you stating that the dinan tune will throw less codes than the "other" tunes is just nonsense. If running more boost on tune x generated a boost leak code, it exposes a vulnerability in the cars turbocharger system - which regardless of tune should be addressed and repaired. If anything, the "other" tunes help expose weakness and vulnerability, and sometimes innefficency.
03-19-2012, 10:34 AM | #11 | |
Knower of all Things Useless
29
Rep 254
03-19-2012, 11:56 AM | #12 | |
3441
Rep 79,211
The stock turbo's are usually passed efficiency around 430WHP. |
03-21-2012, 11:33 AM | #13 |
AC
95
Rep 2,387
no point in discussing how great the tunes are (compared to stock) if the dreaded yellow engine light comes on.
had 6-injectors replaced and the light still come on twice this week after high revs on the engine. taking it to the dealer this week again.
Your Supreme Leader
03-21-2012, 11:39 AM | #14 |
Rep 10,855
I also had 6 new injectors installed at dealer a couple months ago. They cleaned the intake system at the same time. Runs great, although I might replace plugs when I put tune back in. I forget if they reflashed DME.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
03-21-2012, 12:16 PM | #15 |
AC
95
Rep 2,387
did the dealer charged you for the "cleaning"? my dealer was asking for $800 to clean everything (including the internal part of the engine).
Your Supreme Leader
03-21-2012, 02:28 PM | #16 |
Rep 185
I had the HPFP and all of the injectors replaced a few months back, but not the software (long story). Now I have very long cranks that started a few days ago and yesterday it wouldn't crank over until the third try and now is a throwing ABS and 4X4 error codes.
The dealer says it is nothing wrong except it needs the software upgrade, which I am scheduling for next week. We will see. |
03-21-2012, 03:26 PM | #18 | |
AC
95
Rep 2,387
I am now hearing "hissing" sounds from the front of the car, I suspect the problem could be boost leak. The symptoms confirms this as the car feels sluggish under throttle, and misfires under heavy throttle, but no rough idle.
Your Supreme Leader
03-27-2012, 09:58 AM | #19 |
AC
95
Rep 2,387
problem solved. the dealer "cleaned" the carbon build-ups from the intake valves.
I noticed the engine revs up faster and smoother than before. the acceleration feels more "linear" now (just like BMW stock vs. getting kicked from behind when I hit 3.5k RPM and 4.5 RPM on Dinan) looks like I have to get my ECU re-flashed. strongly recommend this get done every 30k miles (or 50k km).
Your Supreme Leader
