PROcede data log
03-17-2012, 01:39 AM | #1 |
Rep 2,567
PROcede data log
Hi guys,
**UPDATE - Added data log of the new 3-13 Stage 3 6AT Aggressive Maps. See below post #18** first time data logging tonight. I'm not really sure how to use the PROcede Datalogging software. I tried using it but didn't work for me. I've attached the CSV file as well as the settings I have the PROcede set to (default) I'm currently running the following... PROcede REV 2.5 - 11-25 stage 3 aggressive maps 6AT Stett CAI Stett CP with forged DV AR catless dp's ETS 5 inch FMIC Vanguard Catless exhaust Can someone load this up and advise how it looks? Much appreciated. Thanks in advance
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current Last edited by TT3 iN NyC; 03-18-2012 at 03:29 AM.. |
03-17-2012, 06:25 AM | #2 |
Rep 7,377
there is something wrong with your boost. leak?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-17-2012, 07:23 AM | #3 |
441
Rep 18,331
I have a funny feeling these aggressive maps do not work for your car like mine. Boost looks terrible. I would go back to the 7-11 maps and it's respective firmware and log again. My car every time I load up anything other than that map, my boost DC would go out the door and my boost would act erratic just like yours.
03-17-2012, 07:36 AM | #4 | |
Rep 2,567
Also, how do I check for any codes? Let's see if an under boost code is present. I'd have to log again tonight when there's no one on the road. Lol too difficult to log in the day.
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
03-17-2012, 07:38 AM | #5 | |
Rep 2,567
03-17-2012, 07:59 AM | #6 |
Rep 582
Try increasing your Boost Control Gain by 5% interval, and replace Road Speed by Boost Control DC% to see better if it's a leak or simply not enough gain on the boost control loop.
03-17-2012, 08:01 AM | #7 | |
Rep 2,567
Also, think updating to the latest 3-13 maps would change anything?
03-17-2012, 09:21 AM | #8 |
Rep 6,631
Log WGDC. It's possible you have a vacuum leak if your boost is tapering off that quickly at that RPM. Did you try the old maps to see if they work fine? Not sure what the monitor name is on procede though.
E90 LCI N54 6AT
03-17-2012, 09:42 AM | #9 |
Rep 2,567
Didn't try the old maps yet. Going to load them up now and see the results. I'll do another data log
03-17-2012, 09:52 AM | #10 |
Rep 2,567
Can someone advise what parameters to log in addition to whats there by default?
03-17-2012, 12:32 PM | #11 | |
Rep 582
03-17-2012, 05:26 PM | #12 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
03-17-2012, 06:58 PM | #13 | ||
Rep 2,567
03-17-2012, 08:24 PM | #14 |
Rep 1,708
OP log boost setpoint along with boost control DC. Almost seems like the map could have been altered with it raising boost mid pull. But boost issue is very likely... WGs, solenoids, leak, etc
03-17-2012, 09:07 PM | #15 | |
Rep 2,567
03-18-2012, 03:19 AM | #17 |
Rep 2,567
hey tzu, no meth kit. new 3-13 map data log posted below
03-18-2012, 03:21 AM | #18 |
Rep 2,567
New 3-13 Maps data log posted
ok so after coming home from a friends house, i did a data log of the new 3-13 maps. please see attached CSV file and screen shot of data log.
03-19-2012, 06:23 AM | #20 |
Rep 2,567
Bump. If someone can provide their input, that'll be great. Not sure how to read these logs. Thanks!
03-19-2012, 08:52 AM | #21 |
Rep 582
Boost in that particular run looks fine, it follows closely the Boost Control Set Point. The original log shown a weird boost curve, but you will have to reproduce it again with those logging parameters for further diagnosis.
The problem you have right now is that your Fuels Trim are maxed out at +34 (maximum of their authority range). Increase your OL Fueling to 100% and try again. Otherwise everything looks in check (AFR should looks better but will once you increase the OL Fueling). Your log reformatted: |
03-19-2012, 09:40 AM | #22 | |
Rep 2,567
I updated to the 3-13 maps and did this log. I'll try to reproduce the first log but i did the exact same thing i did in the 2nd log... only difference was the 11-25 aggressive maps vs 3-13 aggressive maps. What does it mean if the fuel trims are maxed out at +34?
