Is 1000 watts enough power?
03-16-2012, 03:39 PM | #1 |
Rep 13
Drives: E92 M3 ZCP - Alpine White
I'm getting two pheonix gold 10's installed in a couple weeks and I'm wondering if that will be enough power. The e92 is pretty small, but still I like my bass. Anyone have any experience with this subject?
03-16-2012, 06:13 PM | #3 |
Rep 3,161
Yes, if its a good clean 1000 watts its more than plenty. I run 600ish to ea of my 15's.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
03-16-2012, 07:22 PM | #4 |
Rep 255
Look for quality over quantity. There's no real standard for rating amps. Cheapo amps can claim 5k watts and deliver 30w on a good day. Those big numbers are peak power, often in one channel and one frequency. 200-300w should be enough. Look @ Nominal watt rating too.
1. Match the drivers to the right size box, cubic feet of air. Look at manufacturer recommendations on ported box vs. bandpass (sealed). 2. Get an amp stable down to 2ohms if you can. I like Orion, but there's many others. 3. Get a 1 farad cap, otherwise you lights may "blink" when the bass hits and you'll limit top power since you're relying on the battery only. 4. I would go w/4 gauge cable. |
03-16-2012, 08:31 PM | #5 | |
Rep 3,161
03-17-2012, 02:49 AM | #6 | ||
Rep 5,120
To OP assuming your talking about an actual 1000 watt amp it should be pretty loud whether or not it is loud enough is up to you. Also I have no idea how good those subs are or if they'll even take that much power. IMO most car audio brands are crap and many ridiculously exaggerate there ratings. |
03-18-2012, 05:42 AM | #7 |
Rep 115
Caps are useless, just a anchor weighing down your car. If you plan on putting a TRUE 1000 watt amp, I would suggest adding a non spill-able batt. XS power makes amazing batts.
03-18-2012, 07:28 PM | #8 |
Rep 3,201
If you're worried about loud, why limit your cone area?
It's a meaningless question, really. If the question were phrased, "I have this driver which has this amount of excursion and has these detailed specs, I'm using this type of enclosure, and I want to hit this dB level, how many watts do I need to reach that?" then you might have a chance. But as it is, it's a meaningless question. When I ran 1kW of Zapco (50x6/100x2/500x1) in my 2007 328xi, I got a couple of low-voltage warnings. I didn't like the rears anyway, so I deleted them, and the warning went away. I have no reason to believe that your car's electrical system can support 1kWatt of Class AB. I guess my question is, why would anyone add 1kW of bass on a HiFi system? |
