Any Experience With R Compound or ET Tires
03-16-2012, 03:09 PM | #1 |
Rep 5,175
I am anticipating more traction issues in the near future and I am debating what tires to put on my car. I put this in the go fast section because this is simply about getting power to the ground. Have any of you used any R Compound tires or ETs to get better traction? Have you used 19s? Any opinions?
I have only used performance or drag radials in the past, but I don't think that will be enough when I am done. |
03-16-2012, 03:14 PM | #2 |
Rep 3,730
I see quite a few people running DR's on the streets (555R's, NT-01's, BFG's) no so sure about the R-comps though. Hotrod has done a ton of street testing with the DR's, getting some fantastic 60' and 0-60 times. Your best bet would be to go with 18's (or even 17's). Check out AP'EX, they make some affordable light weight wheels. Are you still running the LSD?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
03-16-2012, 03:22 PM | #3 | |
Rep 5,175
03-16-2012, 03:25 PM | #4 |
Rep 3,730
Then buy my Morr VS8.2's 19" @ 19 pounds Sell the Quaife and go with an OS Giken?
03-16-2012, 03:31 PM | #5 |
Rep 78
Some dude on here ran a 1.5x 60ft on the stock wheels with a 245/18 mt drag raidal. Also summit racing sells some sticky stuff to spray on your tires at the track that helps a lot.
2009 135i . Auto. Cpe downpipes, HPF intercooler, BMS intake. BMS meth JB4 with G5 board.
03-16-2012, 03:33 PM | #6 |
Rep 5,175
03-16-2012, 03:35 PM | #7 |
Rep 78
Former boosted is. Are you automatic? And what size or your wheels?
03-16-2012, 03:38 PM | #8 |
Rep 5,175
03-16-2012, 03:39 PM | #9 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
I agree on the Quaife. I love mine. But in a healthy way. Shiv |
03-16-2012, 03:48 PM | #10 |
Rep 5,175
Shiv, would you choose those over the Hoosier R6? Both come in 19 sizing.
03-16-2012, 03:51 PM | #11 |
Rep 1,029
The problem your going to run into with these R Comps is the ultra stiff sidewall. Thats great for the road course, but is going to give you some wheel hop trouble. Id stick with drag radials for DD use.
03-16-2012, 03:54 PM | #12 |
Rep 5,175
That is good info. Is there a drag radial you would have experience with? I have used 555r before with pretty good success.
03-16-2012, 04:29 PM | #13 | |
Rep 1,809
http://www.e90post.com/forums/showthread.php?t=659198 |
03-16-2012, 09:00 PM | #14 | |
Rep 5,175
03-16-2012, 09:12 PM | #15 | |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
The Toyo R888 or the NT-01s (I prefer NT-01s) are a better choice. But they're loud, have a horrendously stiff sidewall and not the best ride in the world, but compromises need to be made.. I can't comment on the DRs, don't do much drag racing my self or daily on them.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
03-17-2012, 10:08 AM | #16 |
Rep 75
I use the toyo R1R. They have relatively soft sidewall for an R compound, pretty good grip and decent wear. You should look into them. I think they are the same compound as the R888 but more tread (not shaved down).
03-17-2012, 05:55 PM | #18 |
Sees the world the way it could be
49
Rep 761
I've run Hoosier DRs on the street before, but on a 17...so I'm not sure I will be of much help. Doesn't MT make the ET Street II in 19"?
03-17-2012, 07:11 PM | #19 |
Rep 1,677
I say go with 18s so you can get thicker tires for more tire flex and raise it up in the rear. Are you thinking about stiffer springs in the rear as well?
03-17-2012, 07:17 PM | #20 |
Rep 1,883
I have driven my FBO+meth MT on both 18" 255/35 Toyo R888 and now, currently, on Nitto NT555R 285/35-18.
My opinion is that the NT555R have given me better traction on the street and at the drag strip. I doubt I'd ever go back to the R888 having driven with the 555R. This opinion is completely based off of straight line acceleration. I haven't really pushed the 555R hard in corners since they have soft sidewalls. R888 did hold nicely in the corner, but overall, my choice would be with the NT555R.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
03-19-2012, 04:36 PM | #21 |
Rep 5,175
03-19-2012, 07:01 PM | #22 |
Rep 610
I run Mickey Thompson street ET's on my TA and they are some of the softest tires I can find. I'll spin em a bit still, but I'm also making almost 600wtq. The nice thing is that when they do shake loose they are still predictable and stay to the road, however I also have a drag suspension setup. I chose those over nt05r's as I felt they were a bit more grippy. The only problem is they don't last long. I'll be lucky to get 7k miles out of them and I drive like a hooligan. Honestly, I don't think you'll find anything stickier in a DR than the MT's.
335i - stock for now
Escalade - Urban Assault Vehicle T/A - Forged ls1, PT8285 turbo, heads, cam, 4l80e w/Transbrake, s60 rear on e85. |
