BOOST ISSUE and JB4 switching maps on it own!!! HELP logging spreadsheet inside
03-16-2012, 07:00 AM | #1 |
Rep 464
Boost Issue
03/18/2012
car is doing alot better...seems to have been bad gas...put shell in and did a bunch of pulls and is now pushing 14psi in all gears. thanks for the help and hopefully problem solved. also been talking with terry so hopefully it works out 03/17/2012 HAVING PROBLEM AGAIN SEE POST #8.. CVS pic on post #14 Last edited by jayk877; 03-18-2012 at 12:49 PM.. |
03-16-2012, 08:33 AM | #2 |
Rep 464
filled up and did a few pulls and now its smooth and pulls like a beast...any ideas on what it could have been? need new plugs? i just installed the downpipes about 12 hours ago
Current car- 2003 cobra S/C stockish
* previous cars 2007 335i e90 Jb4, downpipes, intake, magnaflow exhaust, 375+whp 2005 SRT4 big turbo built to hell.. 420+WHP in a 2700 pound car! |
03-16-2012, 09:21 AM | #3 |
Rep 1,325
Perhaps some sort of adaption/ learning. As long as it is okay how you should be fine. If you want to be safe you can always log and send it to terry
03-16-2012, 12:27 PM | #5 |
Rep 182
Significant changes to your system (changing maps and changing DPs) may require adaptation, 3 WOT runs (3rd gear run all the way out) and you're set. Since the problem went away quickly, that's almost assuredly all it was.
03-16-2012, 05:24 PM | #7 |
Rep 2,013
Ecu needs to adapt to less back pressure, once adapted it will have less lag.
That is why running electric cutouts is stupid, opening them for a race doesnt give the ecu any time to adapt.. |
03-17-2012, 08:08 AM | #8 |
Rep 464
ok so now im having the problem again....the car pulls hard until 3rd gear...gets 14psi and then falls flat after about 60-70 and wont get more than 9psi....ive done a dozen pulls thinking maybe its learning but since its still doing it i dunno what to do....any other ideas? plugs? or dirty valves? what causes boost lose all of a sudden? seemed to pull harder without downpipes...
03-17-2012, 09:17 AM | #10 |
Rep 464
no there are not....just got back from doing logging.....this is very interesting...according to the jb4 i was on map2 and then all of a sudden it switches to map4 during shifting...this is very confusing but im about to post the log in excel form to show everything...and maybe get some answers
03-17-2012, 09:34 AM | #11 |
Rep 464
HERE IS THE SPREAD SHEET...pay close attention to the gears im in and MAP also ONLY getting have boost on map2....any help would be great!!!!
bout to send this to terry and see if he can help! https://docs.google.com/spreadsheet/...WFuWkE3aXB4UXc Last edited by jayk877; 03-17-2012 at 09:39 AM.. |
03-17-2012, 09:40 AM | #12 |
Rep 420
Drives: 2009 E90 N54 TiAg
Did you fix the V clamp this morning? Still runs like shit?
03-17-2012, 09:42 AM | #13 |
Rep 464
yes i did fix that but it wasnt the problem still only running half boost on map2 and then it switches itself to map4 ....im soo confused on wtf but in second gear it pulls hard and is getting 14psi..look at the spread sheet
03-17-2012, 11:50 AM | #14 |
Rep 464
CVS of the map2 switching to map4 also check out the log....seems my AFR is triggering a safety mode in the jb4 hmmmm any thought? i could be completely wrong so help me out with your ideas what could be the problem already emailed terry!
03-17-2012, 12:00 PM | #16 |
Joint Chiefs of Staff
4918
Rep 115,980
The JB4 switches to map 4 for various safety reasons like over boost, run lean, excessive knock detection, etc. In your case since you just put downpipes on I'm guessing it's the run lean protection. Normally triggers after downpipe installs if an o2 sensor is damaged or mixed up. An exhaust leak could also cause it.
Mike |
03-17-2012, 01:57 PM | #17 | |
Rep 464
