02-26-2012, 03:05 PM | #1 |
Rep 699
LF DIY front pipes/X pipe removal?
Hey i have been searching for a e92 m3 x pipe removal. I was wondering if i can do this myself i have a full x pipe primaries and secondaries gone along with resonators, and i wanted to install it this weekend. But have been searching for a DIY and have had no luck. Let me know if you guys think i should try this or if there is a DIY i planned on using jack stands.
Current: 2013 E92 M3 AW DCT
Past: 2011 E90 M3 AW DCT, 2011 E92 M3 MR 6MT, 2008 E92 M3 AW 6MT |
02-26-2012, 06:04 PM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
It's pretty self-explanatory once you look under there. Two bolts each side for the manifolds, pull the o2 sensors, unbolt the bracket in the center holding up the x-pipe, unbolt the x-pipe from the mufflers.
02-26-2012, 06:22 PM | #3 |
Rep 699
think me and my buddy can do it within 2-3 hours? what would you recommend for lifting? besides a lift? jack and stands? Ramps? i was confused on the ramps since i am on coils with a lip.
02-26-2012, 06:25 PM | #4 |
307
Rep 13,093
I don't know your experience level so it would be hard for me to guess a time, but I think it's definitely doable with two people although you'll need to get all four wheels off the ground and fairly high to allow both of you under there to work on it. Without a lift, stands are really your only option. If your car is too low for ramps, you can always get a couple of pieces of 2x6 to get the car a bit higher before it hits the ramps.
02-26-2012, 06:49 PM | #5 | |
Rep 699
02-26-2012, 07:10 PM | #6 |
307
Rep 13,093
