Solar Panel Trickle Charge via this wire?
02-23-2012, 02:16 PM | #1 |
Rep 614
moved from technical forum:
I hope someone can share their experience / suggestions. Project: Install a BlackVue DR400-G dash cam. Use motion detection recording while parked. Objective: Run the dashcam daily without the battery going flat. Possible solution: Trickle charge the battery using solar panel (no access to 110V outlet) Hookup-up: BMW cigarette lighter ports are switched OFF by default after removing the key. If I hookup the solar panel to the "factory battery charging connector", does anyone know if this setup would work? Solar panel: http://www.canadiantire.ca/AST/brows....jsp?locale=en photo credit @eldudo: "factory battery charging connector" |
02-23-2012, 02:33 PM | #2 |
Rep 13,110
The ones that BMW sells
Hook up to the obd 2 port its not switched . About the most you can get is
a 15 watt panel that lays across the entire dash. |
02-23-2012, 05:42 PM | #4 | ||
Rep 614
i found a 15W solar panel and according to posts i've read, i would need a solar panel controller... this is getting more and more complicated. |
