19x10.5 rear
02-23-2012, 01:34 PM | #1 |
Rep 2,486
19x10.5 rear
will 10.5 in the back work on a XI. Im currently on m6 rep with 8.5 and 9.5
want to get 19x9 ET 28 (front) 19x10.5 ET 28 (rear) Last edited by 335_MI6; 03-01-2012 at 04:58 PM.. |
02-24-2012, 06:52 PM | #5 |
Rep 2,486
02-27-2012, 02:48 PM | #6 |
Rep 221
The general rule is to keep the rolling diameters of the font and rear tires within 1% of each other.
But I'm not 100% convinced this is a mandatory guideline. For starters, BMW provided Canada spec models with a staggered option from the factory on XI models. Also, the transfer case has a multi-clutch setup that should match different speeds. |
02-27-2012, 02:53 PM | #7 |
BimmerPost Supporting Vendor
2042
Rep 25,989
From my experience, most people with AWD prefer running a square setup versus a staggered. Something to consider.
A 10.5 should fit with a fender roll and/or pull with a 265 or 275. Be sure to post pictures once you're done. Good luck!
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
03-01-2012, 07:12 PM | #11 |
Rep 5,367
iirc v3's dont cum with front camber plates. Remove the pin to gain -.3 front camber (just taking rubbing precautions) total -.85 fronts.
max out the rear camber at -2.4 dont worry about your xi trans being youre under the 1% rule (.7% difference front n rear tire rolling diameter). 255.30 will be an easy fit with a nice rolled fender.
You can follow my builds on IG: Tee212 |
03-23-2012, 09:10 AM | #12 |
Rep 58
So if I buy a set of OEM style 95's which I believe have an offset of 24 would I have to but camber plates also and max it out? Was thinking about running 235/35/19 in the front and 265/30/19 in the rear
03-23-2012, 09:57 AM | #13 | |
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
03-25-2012, 02:40 PM | #14 |
Fatal Addiction *
34
Rep 23
Drives: 2009 328i xDrive
running 10 will give you rubbing, depends on drop also. DO roll your fenders, you will notice a world of a difference immediately
| 2009 e90 328i xDrive | Space Grey | Vogtland LS | 19" CV1
03-25-2012, 02:41 PM | #15 |
Fatal Addiction *
34
Rep 23
running this w. no problem on vossens ; just roll fenders
03-27-2012, 10:58 AM | #16 |
Rep 58
I'm just going to drop on H&R sports with stock shocks an struts for now. I'll definitely look into rolling fenders now because I don't want to be rubbing all the time
