2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 550i golf tee mod
      02-10-2012, 03:33 PM   #1
s2kdagjd
s2kdagjd's Avatar
45
Drives: G05 M50i
550i golf tee mod
anyone try the golf tee mod on the 550i?
      02-10-2012, 10:18 PM   #2
Fantasm
Algeria
39
Drives: SL63
How the F do I read that?
NOW: 2011 Ferrari 458, 2014 BMW M5 w/ CompPack, 2014 BMW X1, 2005 BMW M3 with Gintani SC&Meth, 2008 Ducati 1098
BEFORE: 24+ Other Awesome Cars - BYE - My Straight Piped Ferrari 458 (plus other mods): http://goo.gl/2qf5fW
      02-26-2012, 01:11 PM   #3
DentalBoy
DentalBoy's Avatar
50
Drives: 2016 M6 Gran Coupe
Can you explain?? Where does the golf tee go?? What does it do?? What are the benefits??
      02-26-2012, 05:01 PM   #4
ImSW1
Drives: F10
Here's some more information. Not my information,I borrowed it from the Youtube link. This is for the 135 and 335.
The popular "Golf Tee Mod". Basically, the stock left side muffler has a vacuum/boost controlled valve that remains shut during idle and part throttle to maintain lower noise levels and opens under throttle for sporty sound. The Golf Tee Mod simply plugs the vacuum line to the actuator just before the exhaust tip, allowing it to remain open at all times for a slightly louder sound at part throttle and idle. Free mod and worth the 3 minutes that it takes to do it.
http://www.youtube.com/watch?v=J2Q1NSNvQvU
http://www.e90post.com/forums/showthread.php?t=80661
From what I understand the 550 uses a different system to open the vavles, so I don't think this would work.
Sean
      02-28-2012, 07:23 AM   #5
DentalBoy
DentalBoy's Avatar
50
Anyone know if this works on the 550i???
      02-28-2012, 12:39 PM   #6
E60orBust
Drives: "The Brothers //M-Sport" E90/2
No, it won't. 3-series exhausts to default-open in the lack of suction, so shorting, disconnecting, or clamping that hose means it can never pull the valve shut, deadening the sound.
The F10 and maybe the E60 before it default-close, so the suction opens the valves on WOT. Disconnecting or pinching that tube means your valves will always be closed.
Down for Maintenance
      02-28-2012, 01:40 PM   #7
DentalBoy
DentalBoy's Avatar
50
Thanks for the clarification
      03-05-2012, 06:26 PM   #8
s2kdagjd
s2kdagjd's Avatar
45
Drives: G05 M50i
wire tied it open...little louder...not much.
      03-08-2012, 10:27 AM   #9
E60orBust
Unfortunately so. Only real solution is a less restrictive exhaust, whether it be an COTS product like AC Schnitzer or Meistershaft or a custom job like this guy.
