CALLING ALL PWM OWNERS! Need help (fuse light)
02-02-2012, 09:26 AM | #1 |
Rep 731
Hey guys, just installed my PWM kit, its not activating once I go into map 4, no flashers..
The only thing I can think of if the RED light on the FUSE does NOT light up. Is this red light supposed to light up at any point? Thanks in advance Travis |
02-02-2012, 09:44 AM | #2 |
Some dude
92
Rep 1,780
Check your settings? Should be about 25 on the flow, injection mode 1.
Or the fuse is blown/defective.
RRT
E92 335i/6MT with stuff and things |
02-02-2012, 09:59 AM | #4 |
Rep 776
I'm pretty sure it lights when the fuse is blown, not when there's power.
Double check your software settings - as james said set meth flow down at 20-25 and you should definitely see indication.. Use the jumper provided on the pressure switch to make sure the pump is coming on. Did you prime the pump with the hose disconnected to see if you are getting strong flow all the way to injector? You can also jump the injector open with the nozzles sitting in a cup to make sure it's flowing all the way to the charge pipe correctly. If all that works the only piece of hardware left is the flow meter. |
02-02-2012, 10:07 AM | #5 | |||
Rep 731
Thanks for the info, I was thinking the injector might have an issue, I will try to jump the injector and will report back. Thanks again for all the help guys, the install was easy. Ready to get it flowing! -Travis |
