sway bars to reduce understeer?
02-01-2012, 04:54 PM | #3 | |
Rep 788
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design |
02-01-2012, 05:55 PM | #4 |
Rep 3,386
02-01-2012, 07:52 PM | #5 |
Rep 788
Then rear....
02-02-2012, 09:43 PM | #6 |
Rep 3,386
someone told me to replace both the front and rears. wouldnt that make my understeer the same as it is now? isnt the point to tighten the back to reduce understeer or am i misunderstanding?
02-03-2012, 07:49 AM | #7 |
Hellafunctional
37
Rep 426
A sway bar does not equal a sway bar. They all have different rates. You first pick your spring rates, then you "balance" the chassis with the sway bars. You can't know what sway bars will balance the chassis when you don't know the spring rates or the sway bar rates.
Therefore, nobody is able to answer your question as it stands. We need spring rates and bar rates.
Go: Cobb S2+, Big Tom FMIC, CP-E DP & DCI, Royal Muffler, AR OC Turn: TC Kline/Swift SA, Vorshlag Plates, UUC Front Bar, H&R M3 Rear Bar, VAC endlinks & spacers, Forgeline 18x9.5/NT05 265 Square Stop: Endless MX72, Stoptech Rotors/Lines, Motul RBF600 |
02-03-2012, 12:50 PM | #8 | |
Rep 3,386
02-03-2012, 01:20 PM | #9 |
Hellafunctional
37
Rep 426
You asked how to reduce understeer. Understeer =/= body roll. Roll is only a single factor in determining chassis balance. Even then, it is the relative front/rear roll, not overall body roll.
Unfortunately H&R don't advertise their spring rates, so it is a little hard to help you out. I would grab the e90 M3 rear bar and see how that feels.
02-03-2012, 01:21 PM | #10 | |
Rep 566
Drives: 2006 330xi 6MT
02-03-2012, 06:20 PM | #11 |
Rep 3,386
http://www.e90post.com/forums/showth...light=sway+bar
i found this. as i thought before these people seem to think adding the front sway bar will continue my understeer problem where as the rear will reduce understeer |
02-03-2012, 09:52 PM | #12 | |
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
02-03-2012, 11:25 PM | #13 |
Rep 2,590
02-04-2012, 12:03 AM | #14 |
Rep 3,386
these are the spacer options on BMS website. 10,12,15,18
i dont know if this helps decide what i should get but heres my rim and tire dimensions. Tires Front: 235/35/19 Rear: 265/30/19 Rims Front: 19x8.5/ET-35 Rear: 19x9.5/ET-33 thank you guys for all your help |
02-04-2012, 07:35 PM | #17 |
Rep 1,133
02-05-2012, 12:52 AM | #18 |
Rep 3,386
i spoke to Mike at n54tuning and he told me that i should only get a rear sway bar and not a front. i will also look into spacers. can i ask the dealer to put those on when i change back to my summer wheels or is that something that would void warranty if something happens to like my bearings or something? thanks
02-05-2012, 03:46 PM | #19 |
Rep 3,386
Alan at **********s told me this:
The of the major function of sway bars is to tune the handling balance of a car. Understeer or oversteer behavior can be tuned out by changing the proportion of the total roll stiffness that comes from the front and rear axles. Increasing the proportion of roll stiffness at the front will increase the proportion of the total load transfer that the front axle reacts and decrease the proportion that the rear axle reacts. In general this will cause the outer front wheel to run at a comparatively higher slip angle, and the outer rear wheel to run at a comparatively lower slip angle, which is an understeer effect. Increasing the proportion of roll stiffness at the rear axle will have the opposite effect and decrease understeer. you guys were saying u need to know my spring rate etc but doesnt this answer the question without knowing that stuff? |
02-05-2012, 03:57 PM | #20 |
Rep 1,133
It's my understanding the sway bar is already larger for the XI. Does anyone have the breakdown, 325i, 328i, 328xi, 335i, 335xi, M3?
02-05-2012, 04:12 PM | #21 |
Rep 3,386
02-05-2012, 05:45 PM | #22 |
Rep 3,386
Alan at **********s just found this for me:
335i Rear Sway Bar: D=13MM 33556764425 335xi Rear Sway Bar: D=15MM 33556764427 the m3 one is 20mm. do you think going from 15 to 20 is a big enough difference to do something? |
