Compression Test - What fuel fuse and WOT?
01-28-2012, 10:30 AM | #1 |
Rep 75
Hey guys. Do you know which fuse is the fuel pump/relay so I cut fuel for a compression test.
Also, I need to have the throttle wide open...how does that work on our drive by wire cars. If I press the peddle down all the way when cranking, will the DME open the throttle? Thanks |
01-30-2012, 12:43 AM | #3 |
Rep 98
If you are looking for a bum cylinder, you dont necessarily need to have the car at WOT. Compression tests are more accurate with it open, but in my opinon, you really just want to make sure all the cylinders are in a similar compression range. Using this method, the bad cylinder will have a large gap between the compression of the other cylinders.
On the other hand, if you are not hunting for a bad cylinder then you will need it open for accurate readings. As for the fuel pump fuse, i cant help you there. Ive never had to look for it. You can always look in the throttle body to see if the throttle flap is open when the car is off and the pedal is down.
2008 BSM 335i coupe- Sport.Premium.Dakota Sadel.jb4.dci.meth
1999 Pontiac Grand Prix-10.5 PSI.PRJ LL CAM.Supporting Mods |
01-30-2012, 06:04 PM | #4 |
Rep 75
That is what I was thinking. I was getting roughly 115-120psi on all except for the one that was chewing up my plugs was at 110psi. I felt pretty good after that but really should be quite a bit higher than 200psi.
