2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Can I retrofit 535i rear exhaust with 550i ?
      01-28-2012, 03:13 AM   #1
///Marco.it
///Marco.it's Avatar
9
Drives: F11 535i Msport
I am pretty in-loved with my F11 535i Msport. Perfect combination between power, handling and fuel economy.
The only think I do not love are the two round tailpipes.
Last week I have seen an F11 550i and I must say that the trapezed shape tips are much better and in line with the car's design.
I looked at many threads and I am still in doubt if I can retrofit the 550i mufflers. The main doubt is about the two central pipes with the butterfly valve. How to keep them always open as the 535i does not have them. The two pipes on the 535i are both direct with no valves whatsoever. Keeping them closed I am afraid to reduce too much the gas exit while keeping them open should be the same as on the 535i mufflers. This considering that the two 535's tips together should have more or less the same diameter/area of the 4 550's pipes together. Each 535's pipe has bigger diameter than each 550's pipe.
Any suggestion or contra indication?
2013 - BMW Motorrad R 1200 R, Smoke Grey Matt
2011 - BMW F11 535i ///Msport, Alpine White
2009 - MINI R56 COOPER, Mellow Yellow
      01-28-2012, 01:43 PM   #2
dogruyolk
Drives: Bmw F10 520d
I asked my dealer about 550 tips. Answer was "it is embedded to back exhaust". They said that if something happens to tips, you need to order back exhaust and replace it which is ridicilous and expensive.
      01-28-2012, 08:57 PM   #3
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
Or find somone selling 550 exhaust and gi from there. With regards to the valve, is it electronic? If so then that can be retrofitted. If its vaccum activated, then youll have to get more creative.
Let us know how it comes out.
      02-07-2012, 12:45 AM   #4
Park828
Drives: Man
im not 100% on f10 but on e90.. it was vac controlled and default was open... application of vacuum Closed the valve.
      02-07-2012, 01:56 PM   #5
Beemw335
Drives: 335i
The 550i exhaust uses vaccum to OPEN the valves, therefore on a 535i they will always be closed which doesnt really matter since its for sound anyways.
What i recommend you do it either get an aftermarket quad exhaust which will lok nice, or just get a 550i exhaust and on top of the tips you will see the vaccum controlled arm to opens the valves, well just pushh the arm to the open position and use a metal clamp to hold it there, therefore the valves are always open which will sound a bit better and still wont drone.
      02-12-2012, 02:22 AM   #6
EBRSKIH
Chef
17
Drives: F10 550i
I actually have a used OEM 550i exhaust for sale. NON M SPORT. Let me know if youre interested
2013 X6 50i Sapphire Black
2012 550x Alpine White
- 12.727@108 - 1.7 60ft lemon'd
2011 550i Sapphire Black
- 12.960@109 - lemon'd
