Jb4 with stock bypass on
01-26-2012, 12:55 AM | #1 |
Rep 210
My car feels unsmooth (jerky is too harsh) upon acceleration in stock bypass mode. Almost like its lunging as I accelerate. map 1 and 2 are smooth as silk. I have dci and dp\'s. Anyone else experienced an almost rhythmic pulling sensation upon acceleration? I can try and get a video tomorrow. Car is 07 e92 with 70k miles. It did not do this with the jb4 out and stock air box. Going to switch out dci with air box tomorrow to see if that\'s the issue. Otherwise I suppose I have something wrong with my engine. Any advice is appreciated.
01-26-2012, 10:46 AM | #3 |
Joint Chiefs of Staff
4918
Rep 115,980
On map 0 the JB4 is in bypass mode, so its likely your DME complaining about the downpipes and intake. As long as its running normally on a JB4 map I doubt you have any real issue.
Mike Last edited by Mike@N54Tuning.com; 01-26-2012 at 10:55 AM.. |
01-26-2012, 02:11 PM | #4 |
Rep 210
Terry said my logs were ok but said my waste gates were tight. I'm getting more waste gate rattle since installing dp's. Is the rattle just an annoyance or is it something worth fixing. Could bad spark plugs cause the oscillating, lunging feeling on stock?
01-28-2012, 09:29 PM | #8 | |
Rep 142
When the car is misfiring and running really bad, My butt dyno told me about 50hp. Once the car stopped misfiring after spark plugs. it was like i installed the tune for the first time.
01-29-2012, 08:56 AM | #9 |
Rep 457
Did you notice what the old plugs looked like? ie carbon build up, electrode degredation?
2008 E92 335i M-Sport | Sapphire Black | Sunroof | Creme Beige | Poplar Grey | Logic 7 | 6AT | 19" AG M359's | Michelin PS4S | LUX V3 | MHD V5 E40 | Steve AZ Walbro inline | Vishnu DCI | BMS CP | AR Design Catless DP's | Forge DV's | Helix IC | (Stock Cat. back) |
01-29-2012, 09:47 AM | #10 | |
Rep 1,827
I had about 55k on the original plugs and the electrodes were degraded. New plugs transformed the car again into the way it was before. |
01-29-2012, 05:15 PM | #12 |
Rep 632
06-22-2012, 09:27 PM | #15 |
Rep 120
Im installing the JB4 and DCI in tomorrow. I already got around 96k on the car. Within the next few days im going to change the plugs just to be on the safe side
06-23-2012, 07:49 PM | #16 | |
Rep 965
Drives: e92 m3
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
06-23-2012, 10:05 PM | #17 |
Rep 623
80% of them are in pretty damn good condition for being that many miles on them...
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
06-24-2012, 10:37 AM | #18 |
Rep 788
Did u get any residue around hole where plug goes in?? Mine were worst than yours. I changed all coils and plugs same time.
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design |
06-24-2012, 11:50 AM | #19 |
Rep 2,396
Drives: '08 E90 335i
Consider a replacement Valve Cover Gasket (#11127565286). I was getting misfires, replaced my spark plugs & my #3 plug was in similar condition: slight coating in oil, but not dripping (which would indicate a very bad leak). My mechanic recommended the replacement gasket.
I'm going to have my intake valves blasted next month & will be replacing the gasket at the same time to avoid getting hammered with additional (and unnecessary) service hours. As for Ignition Coils, IMO it makes the most sense to replace all 6 at the same time (and the same w/ spark plugs) since after one fails, the others will follow shortly. |
