E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > stock Intake and BOV questions
      01-23-2012, 11:52 PM   #1
Weltdriver
Drives: 2009 AW e92
Alright first to start off, yes I did my search and I know that there plenty of intakes that make the car sound much meaner and there are plenty of BOVs to go wit them.
On my 350z I had an intake and didnt see a problem with it since I did my own maintenance. Now with BMW I would not want to take it to dealer with DCI installed (just to be safe) let alone a BOV (if ill get 1)
So my question is,
1. is there a simple way to modify stock intake (maybe get a diff filter for it? KN?) to add a but of growl
2. What is a good sounding BOV that is pretty easy to install/uninstall.
Thanks guys
      01-24-2012, 12:06 AM   #2
rader1
Drives: Cobb Stage 2+ 135i
There are a few drop-in filters that go in the stock airbox, but they don't increase sound. A DCI is really easy to install/remove for dealer visits. Checkout helix13.com, they have 2 different BOV setups that fit right into the stock DV slots. Forge also makes DVs that you can vent to atmosphere.
Edit: you can also search for DIY BOV and you'll find a way to turn your stock diverter valves into BOV for about $3 and it's super easy/reversable
      01-24-2012, 12:42 AM   #3
Weltdriver
Drives: 2009 AW e92
Will research those options! Easily reversible always sounds good.
Thanks
P.S. I am guessing DIY BOV wont sound as good as the Helix or Forge BOVs?
      01-24-2012, 12:53 AM   #4
rader1
Thanks
Its all opinion on sound, but honestly the DIY BOV setup doesn't sound bad. All you do is unhook the factory DV tube from the intake pipe(NOT the DV itself, but the discharge hose coming out of the side. It has a light grey locking clip you need to rotate to remove) and cap the fitting where the hose connected. It takes about 5 minutes to do. Homedepot sells 1" Inside Diameter black rubber caps that work great and matches the black plastic. IMO, the only downside is that it looks bad to have uncoupled hoses in your engine bay
If you decide to do an aftermarket intake there are hundreds of discussions on what is the best and the general consensus is that they're all pretty much the same. So go with the most popular/cheapest, which is the BMS DCI.
      01-24-2012, 12:56 AM   #5
Weltdriver
Drives: 2009 AW e92
      01-24-2012, 01:05 AM   #6
idrift4wd
Drives: Three Hundred and Thirty Five
2007 BMW  [7.00]
DCI.... and take off the engine cowl(for dry days) Youll be absolutely happy.
      01-24-2012, 09:56 AM   #7
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
That'll work, but beware that there are moments of vacuum in the intake runners, and you'd be sucking in un-filtered air: not so good.
      01-24-2012, 10:03 AM   #8
rader1
My understanding of the N54 is that there is always pressure in the chargepipe. whenever the stock DVs are "open" the throttle plate is closed and there is pressure, not vaccuum, so air can't be drawn in throught the DV.
Correct me if i am wrong here.
      01-24-2012, 10:11 AM   #9
MDORPHN
Drives: AW 1M
As others have stated, a replacement panel filter won't affect noise.
I briefly ran with BMS dci and now have Helix's new set-up and like it a lot.
There is more intake noise with the BMS dci, but I didn't much like how it looked in the engine compartment.
Neil
P.S. OP: If you're interested in a slightly used BMS dci, contact me offline.
      01-24-2012, 10:20 AM   #10
eric@helix
eric@helix's Avatar
In theory, yes, but a very good engineer suggested to me otherwise...
      01-24-2012, 11:12 AM   #11
Weltdriver
Drives: 2009 AW e92
Thanks to everyone for you replies!
Is this just with DCI or with the DIY BOV mod as well? I hear a little whoosh before shifts
      01-24-2012, 11:14 AM   #12
idrift4wd
2007 BMW  [7.00]
just DCI and took off engine cowl. no BOV DIY performed. Its much louder in person. You'll be really satisfied.
      01-24-2012, 11:22 AM   #13
zeel
Drives: 08 AW e92 335i
if you want a prettier DCI, check out CPE's option on BMS's website
e90post
