Cobb + JB4 logs map 6 additive Virtual dyno
01-20-2012, 11:51 AM | #1 |
Rep 7,377
I run today couple of pulls to test the new flash version of map 6. Basically you can add boost/additive per RPM when meth is flowing.
Base map STage 2+ FMIC. This is a log a Virtual dyno with 5 + psi at 7000 rpm, 4 psi 6500 rpm, 3 psi 6000 etc. Dual nozzle 1050 ml/min meth. quite cold out 27C , lots of traction problems. There is also a new function in Vdyno that allows now to do and check graphs, pretty cool . overall i am happy with the combo and can push even more boost if needed. Fuel pressure set to 50 , need probably to increase it a bit.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
01-20-2012, 12:06 PM | #2 |
Rep 6,631
Hmm... Good info but your AFR doesn't appear happy. I know when I was testing my Cobb + JB combo a 90FPadd caused insanely negative trims, 40 seems to have fixed it. Try the 90FPadd see if it helps.
Are you running a 15 ohm board?
E90 LCI N54 6AT
01-20-2012, 12:26 PM | #4 |
Rep 6,631
Look like a WOT onset throttle closure. Happens when the dme perceives an overboost condition.
E90 LCI N54 6AT
01-20-2012, 12:36 PM | #5 | |
Rep 7,377
Nice though it works perfectly fine. More testing later on.
01-20-2012, 12:49 PM | #6 |
Rep 6,631
You're not really running that aggressively in terms of boost or timing so perhaps that's why your trims are going so negative with the fuel pressure bump. I understand though, traction is a problem for most of us right now!
E90 LCI N54 6AT
