My virtual dyno results
01-19-2012, 04:36 PM | #1 |
Rep 39
I have a 09 335xi with JB4, DCI, and meth. Not sure how accurate this is, but it is interesting.
01-19-2012, 04:38 PM | #2 |
Rep 7,377
thats way to much boost for stock dps... also quite lean in midrange.
Use smoothing 4 or 5 as well.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
01-19-2012, 04:56 PM | #5 |
Rep 7,377
logs can look fine but i wouldnt run more than 16 psi on stock dps especially since you live in germany and you probably do long high gears pulls on the autobahn. get some catless dps at least.
01-19-2012, 05:05 PM | #8 |
Joint Chiefs of Staff
4918
Rep 115,980
AFR looks lean on tip in, but without seeing all the other data it's hard to make any conclusion there. The AFR is read from the OEM wideband and then a bias applied, so if the bias is shifting you can get a false lean reading. Also it can look fine on one log and not another. Just something to keep an eye on. If you like testing things they have a firmware with richer low end AFR targets you could try.
Mike |
01-19-2012, 06:04 PM | #10 |
Rep 632
01-20-2012, 03:58 AM | #12 |
Rep 7,377
at least hit 12.5 straight away tapering down to 12 but yeah we should see couple of logs.
