New Vishnu Methanol Pumps
01-18-2012, 07:53 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
For the last several weeks, all our PWM Methanol kits have been shipped with a new pump design specifically manufactured by Aquatec for use in system. Compared to the standard 5800 series pump used by others (Coolingmist, Devils Own, AEM, etc,.) our proprietary pump has some key differences: Motorsport grade 2-piece compression fittings & bushings-- A nice upgrade from the usual, somewhat annoying push-in fittings which tend to leak over time. These compression fittings are the same design as the other compression fittings used in the PWM meth kit... just much bigger (for the 1/4" meth tubing) and complete with rubber o-ringed bushing fitting. Unfortunately, they aren't cheap (they cost us nearly as much as the pump itself!). But it also means that they will NEVER leak. Which is a good thing Higher Flow Rate-- Our pump spins at 1625RPM compared to the standard pump at 1400rpm. As such, it is rated at 1.3GPM (gallons per min) versus the standard pump's 1.0GPM. What this means is that it is able to maintain system pressure better when running multiple nozzles/high meth flow applications. The higher pump RPM also means less pressure pulsations for a smoother operation. This is immediately noticeable (they sound different) when running both pumps side-by-side. The price of the new pump (with compression fittings/bushings) is $245. To order, please email us at sales@vishnutuning.com. By no means is this a mandatory upgrade. It's just an improvement to an already well-functioning component. Perhaps something to consider into when it comes time to replace your pump. Older pumps with push-in fittings cannot be retrofitted with compression fittings. Cheers. shiv |
01-18-2012, 08:28 PM | #2 | |
Rep 2,841
Can't see it in the pictures. |
01-18-2012, 08:32 PM | #3 |
1737
Rep 17,960
Drives: A Lot
It provides the seal between the pump head and the tightening nut I'll take some close up pics of the fittings themselves tomorrow and post them up here. They are pretty.
01-18-2012, 08:53 PM | #5 |
441
Rep 18,331
This is a pretty awesome pump! These rapid fittings are the best compression fittings for nylon tubing. These suckers are so hard to come by and I have been searching for a week to find them. You have to buy quantity from the Manufacturers in China to have them even send you some. Only place that has them in the USA is out of stock for 4-5 weeks! When my pump ever fails I am buying this pump. Good job Shiv
01-18-2012, 10:45 PM | #6 |
Rep 10,587
those look identical to the compression fittings that aquamist uses on the hfs6 (pretty sure), thats a good thing.
01-18-2012, 10:47 PM | #7 |
1737
Rep 17,960
Drives: A Lot
That's because they are sourced directly from Aquamist These aren't the inexpensive Camozzi fittings that people have used with varying levels of success. We aren't looking to save a few bucks when the alternative is a pressurized methanol leak.
01-18-2012, 10:47 PM | #8 |
Rep 3,730
Wanna sell me just the tubing? My push fittings on the T are leaking, they suck if you don't cut them perfectly clean and flush.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
01-19-2012, 12:56 AM | #9 |
1737
Rep 17,960
Drives: A Lot
Push-in fittings generally aren't the greatest because, as you see, they are very sensitive to tubing integrity and cut. We have a few thousand feet of meth line here so just call us if you need some
01-19-2012, 01:00 AM | #10 |
1737
Rep 17,960
Drives: A Lot
And here is a close-up of our fittings (they are specifically built for Aquamist):
By comparison, here is a $5 push-in fitting from Camozzi: |
01-19-2012, 09:10 AM | #12 | |
Rep 2,841
Terry is just being his usual cheapskate self on the other forum and having a hoot thinking all procede customers are born suckers. . Maybe he's right in some regards......meh. But I think it's more a case of . . . . . His story made no sense about this being a new "prototype" pump that was recently sent to all vendors for evaluation. I asked him why the Vishnu version would have a different bypass pressure and he indicated that spring rates can be changed when vendors order the pumps. Hmmmmm.....so if this is a newly released prototype then how has Vishnu been using it for a couple of months now with custom spring rates? Honestly if people want to spend a little more for better quality that is their choice. The burger team always quickly points out that there is no difference between the kits at 100% duty cycle. Maybe so.....but I don't drive at WOT 100% of the time. Got it yet guys! Nice to also see the upcoming programming change to the Procede which manages meth flow more accurately at part-throttle settings. I was fearful of venturing into meth territory, but have to say that the Vishnu kit is truly plug and play and has excellent driveability. No regrets. . Last edited by Ilma; 01-19-2012 at 09:22 AM.. |
01-19-2012, 09:30 AM | #13 |
Rep 6,631
You do understand short term fuel trims have a fairly robust adjustment scale, right? Other than saving some meth at part throttle, the ECU will make the proper adjustments if methanol is introduced at full flow under part throttle conditions. Plenty of logs showing this example in action. If the fuel system wasn't fully closed loop I would be first in line to get a setup like this; but the only benefit in the real world is saving some meth under part throttle and the overall reliability of Aquamist components over their lower-cost PPS competition.
E90 LCI N54 6AT
01-19-2012, 09:31 AM | #14 | |
Rep 10,587
typical, totally typical. and lol at the 100% claim, duh!! 100% on a pump is 100% assuming they can both flow the same at 100%, its what they do the other 99% of the time that matters. all comes down to control and programming, both of which Terry has always been bounds behind Vishnu since Terry started playing with resistors......coached along by Shiv until he smelled a rat.
01-19-2012, 09:46 AM | #15 |
Rep 3,262
so if u are ordering a complete kit it will come with this new pump right? the 245 is only for people looking to upgrade their existing pwm kit?
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
01-19-2012, 10:06 AM | #16 |
Team Zissou
3065
Rep 10,197
01-19-2012, 10:40 AM | #17 |
Rep 124
you said that for the last several wks all kits have been sent out with the new pump, but I just picked up my kit from you guys last monday and got the old pump with it
01-19-2012, 12:00 PM | #18 | |
1737
Rep 17,960
Drives: A Lot
And to reiterate, the release of this pump does not imply that something was wrong with the previous pump. It performed great and is still in both our shop 135 and 335. But when the time comes to replace pumps (or run additional nozzles), I'll making the switch. The fittings just just add a bit more peace of mind. Regards shiv Last edited by OpenFlash; 01-19-2012 at 12:16 PM.. |
01-19-2012, 12:22 PM | #19 | |
1737
Rep 17,960
Drives: A Lot
Since you fall in during the transition period and are local, we can swap your pump out when we get more stock next week. But again, there is nothing wrong with your pump. There are several hundred other PWM users using it quite successfully Shiv |
01-19-2012, 01:06 PM | #20 | |
Rep 124
other than that the system is amazing and I love it. the install was very easy. tahnks guys |
01-19-2012, 01:10 PM | #21 |
Some dude
92
Rep 1,780
I have the older pump and see no need for me to upgrade unless there is a failure or persistent leak, or if you need the extra flow for larger nozzles. When I trimmed the hoses, I used a sharp hose cutter to ensure a clean, perpendicular cut. Or you can use a new, single edge sharp razor blade.
It's been flawless since early November 2011. Since I do intend to track this car, I am glad I went with the PWM setup to ensure smooth delivery at part throttle. Very happy with it, and it was a breeze to install.
RRT
E92 335i/6MT with stuff and things Last edited by JamesM3M5; 01-19-2012 at 02:36 PM.. |
01-19-2012, 10:58 PM | #22 |
Rep 968
Drives: 2007 335i Coupe
Terry = Major Fail. Lol!!!!!!!!! He just does not get it.
