XI TROUBLE
01-16-2012, 11:47 AM | #1 |
Rep 122
XI TROUBLE
So I woke yesterday with a rwd car... abs, dtc, 4x4 all disabled... scanned the car and here are all the codes that appeared under transfer case in BT.
5251 - incremental encoder supply, signal or value under threshold 5461 - error actuator control 5462 - error actuator or increased power requirements for fpr clutch 5463 - break mechanics 55C3 - all wheel not activated 54C8 - class resistance at actuator 54C9 - temperature sensor actuator any advice well be much appreciated
COBB PROTUNE/HFS4/AFE STG 2 DCI/ BMS OCC/AR 3" C*tless DPs/ER CP/Forge DV's/ Eibach Pro springs/M3 suspension bits/CF rear diffuser/ 30% tints / Lightly smoked tails/ Blacked out grill /SSP clutches
01-16-2012, 03:46 PM | #6 |
Some dude
92
Rep 1,780
Have to get it checked out at a shop that can check the transfer case. There is a stepper motor that tightens up the clutches to increase front drive. Sounds like either the motor or the position sensor on the motor are dead. Otherwise you have a bad transfer case and need to replace it.
RRT
E92 335i/6MT with stuff and things |
01-17-2012, 06:38 PM | #7 |
Rep 122
all the sensors are good, cleared the codes and disconnected the battery and 4x4 warning came back on at start up... looks like the vtg motor is dead, going to the dealership this week to get a new one... thanks for the help guys
