Gaskets at turbo to downpipe reusable?
01-13-2012, 01:09 AM | #1 |
Rep 2,229
What's up fellas, finally going to install my iCarbon ceramic coated DP's after having them sitting around for a little over a year lol and i was wondering if the gaskets at the turbo to the downpipe are reusable or should i buy new ones for the install? Thanks in advance!
#3 in diagram for reference |
01-13-2012, 01:27 AM | #4 |
Rep 6,631
I just did turbos, I replaced the turbo to DP gasket with a new OE gasket. The gaskets that connect the downpipe to the exhaust are a must though.
E90 LCI N54 6AT
01-13-2012, 06:54 AM | #5 |
Rep 1,551
Unless its worn away, I wouldn't worry about it. I've done and redone by DPs about 4 times, and by then it was beginning to show signs of wear, after flaking so much. I'll probably replace that packing when I do them again.
01-13-2012, 08:04 AM | #8 |
660
Rep 1,059
Do those turbo to DP gaskets usually stick to the turbo? I just did DP's and I don't remember seeing those gaskets. I'm assuming they stayed on the turbos without me realizing it.
01-13-2012, 08:07 AM | #9 |
Rep 770
01-13-2012, 08:30 AM | #11 |
812
Rep 3,974
If they are sticking to the DPs I would probably replacement. Otherwise just leave them in and you can reuse them. I had my DPs on/off several times, no problems.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
01-13-2012, 11:03 AM | #13 |
Rep 3,730
Only ones I would trust to re-use are your AR Bomb-proof gaskets.....OP pick some up to replace #6.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
01-13-2012, 11:36 AM | #15 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Reuse if they did not split in half when the DPs were removed. I had a set of gaskets ready when the my AR downpipes were installed. The original gaskets were fine, but I still insisted on replacing them. Cheap insurance against exhaust leaks.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
01-13-2012, 11:58 AM | #16 | |
660
Rep 1,059
01-13-2012, 04:59 PM | #17 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
Maybe it melted?? I looked in my stock downpipe and still dont see anything..This is tripping me out
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
01-13-2012, 05:30 PM | #19 | |
105
Rep 1,133
Will the turbo side leak if the gasket is not there?
01-13-2012, 05:40 PM | #20 | |
Rep 225
You'll be fine. I didn't see mine either when I installed my AR DPs last weekend... |
01-13-2012, 08:53 PM | #21 |
660
Rep 1,059
Until this thread, I didn't even realize there was such thing as a gasket for a v-band flange! I've installed numerous turbo's, exhausts and headers and 100% of them didn't have a gasket at the flanges.
01-13-2012, 09:45 PM | #22 | |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I've done DP installation over 10 times and have never had the gaskets come out of the groove in the turbo housing. I would not replace those unless they are cracked or flaking away. |
