Can 40 lbs reduction in unsprung weight make a difference?
01-12-2012, 10:14 AM | #1 |
Rep 88
Guys, can a 40 lbs reduction in unsprung weight make a big difference in a drag race?
The reduction is coming from lighter wheels and moving to non-RFTs. Is the difference noticeable in a drag race to justify around $2,000? I am already FBO |
01-12-2012, 10:16 AM | #2 | |
dat boost doe
238
Rep 1,823
but the difference in ride, handling, braking, and acceleration is fucking fantastical.
01-12-2012, 10:19 AM | #3 |
Rep 2,669
got yelled at by a mod so i edited this, forever alone =p
Mod adds: Mea culpa -- I am not a mean guy. Plz accept apology. Stressdoc aka yelling mod Last edited by E90SoFlo; 01-12-2012 at 10:40 AM.. |
01-12-2012, 10:24 AM | #4 |
Rep 3,730
Unsprung weight is HUGE! You will feel it instantly, especially with 40 lbs. I felt an amazing difference when I switched from CSL wheels to forged light weight rims. 1 lb of unsprung = 2 lbs of static weight in performance gains.
80 lb subs are not unspung weight.....
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
01-12-2012, 10:25 AM | #5 | |
Rep 10,855
To the OP: he!! yes 40 lbs makes a huge difference in performance -- not so much for drag racing (at our levels, it is all about more power and traction), as for handling. Acceleration will be faster as the rotational mass of the wheels you are turning is lighter. But more significantly, your suspension has so much less momentum to control with that much weight loss. That said 2k is a lot of $.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-12-2012, 10:25 AM | #6 |
Rep 1,244
Unsprung weight is most obvious in regards to handling. I don't know if you'd notice it much in a drag race, but you'd really feel the difference on the track or street. 40lbs is still 40lbs so you'd probably shave a thousandth on a dragstrip, but I think other variables would be more of a factor.
01-12-2012, 10:33 AM | #7 |
Rep 6,631
There was an article on tire rack about the effects of unsprung weight on straight line acceleration. Dropping 9 lbs per corner net the test car 1 mph in the quarter mile. Do a search for the article on Tirerack. Difficult to do it on a phone.
E90 LCI N54 6AT
01-12-2012, 10:40 AM | #8 |
dat boost doe
238
Rep 1,823
google "unsprung weight" please.
01-12-2012, 10:41 AM | #9 |
Rep 2,669
Jesus you guys are so fucking serious about everything, calm down. I didn't even read the OP's entire post. CALM DOWN.
To the OP: Yes 40 pounds are noticeable.. You will prefer the non RFT also. |
01-12-2012, 10:49 AM | #10 | |
Rep 1,432
1lb = 2lb -> 40lbs = 80lbs |
01-12-2012, 10:56 AM | #11 | |
Rep 1,432
Wheels and tires just happen to belong to both rotational and unsprung categories. |
01-12-2012, 10:56 AM | #12 | |
Rep 88
i thought to myself if i can spend 2 grand and save 40 lbs to make my car much faster why the he11 not??!! but again if that is true, everyone would have done it.. what do you guys think? |
01-12-2012, 11:03 AM | #14 |
210
Rep 1,161
A rule-of-thumb for adding power or dropping weight is that you need to gain about 8-10 WHP, or lose the equivalent weight to feel a difference in performance from the driver's seat. Losing the equivalent of 80lbs (40 unsprung) should make a noticeable difference in the car's performance.
01-12-2012, 11:15 AM | #15 | |
Rep 88
yeah you are right, i am better adding meth for less than $500 and get the 30-40 whp !!! |
01-12-2012, 11:15 AM | #16 | |
Rep 1,432
Rotating mass |
01-12-2012, 11:50 AM | #17 | |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
01-12-2012, 11:57 AM | #18 |
Rep 1,883
For $2k its not worth it, from a drag racing perspective. You would be lucky to lose 0.1s off your time and maybe gain 1mph. If you are a manual transmission and the tires you are switching to are not drag radials, you will probably never see that gain as it is EXTREMELY hard to be consistent on your launches with street tires.
My opinion, get rid of the run flats and go with a non run flat performance tire. They are cheaper than run flats and will give you better traction. Only get the rims if you really like them. Spend the rest of the money on a meth kit. It is the second best thing to making your car faster, right behind a tune. You will easily gain a minimum of 2 mph with meth.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
01-12-2012, 12:05 PM | #19 |
Custom Powder Coater
147
Rep 2,784
I think it makes a significant difference in all these 60-130 times.
You can lose 15 lbs per wheel/tire if u go with super light 17-18 lb wheels, and light tires like Continental DW and Pilot Super Sports.
01-12-2012, 12:06 PM | #20 |
242
Rep 2,781
Drives: E90 335i Racecar
Yes. Lighter wheels = less rotational mass. That is very good.
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
01-12-2012, 12:30 PM | #21 | |||
AC
95
Rep 2,387
$2k and you get 40lbs reduction? you got a lot of value there.
I am looking at BBS RGR rims and it will net me 48lbs in savings, but the rims costs $4k. I doubt your rims are forged and they provide that much weight savings for only $2k. At your price point, you will only get cast-aluminum rims, which will be around 20lbs (5lbs per corner) in weight savings. Quote:
Your Supreme Leader
01-12-2012, 04:17 PM | #22 | |
Poor Kid with Dreams
28
Rep 702
162 F: 30lbs 162 R: 32lbs Apex F: 18.45lbs Apex R: 18.85lbs Wheel Savings: 49.4lbs Bridgestone RFT F: 25lbs Bridgestone RFT R: 26lbs Conti DW F: 21lbs Conti DW R: 23lbs Tire Savings: 14lbs Total Price $1966.00 plus shipping That's the setup I'm going with anyway...
'07 BSM 335xi JB4, DCI, CX Racing I/C, ER Chargepipe, Meth, KW V3 - Pending Sale '95 Mustang GTS 347ci Ported TFS TW Heads,Custom Cam,Victor 5.0 IM,Tubular Front Suspension,Full Exhaust,Big and Littles |
