E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Smoke from the exhaust!
      01-11-2012, 11:22 AM   #1
T!m3
BMW maniac!
T!m3's Avatar
Drives: ///M3 e92
Exclamation Smoke from the exhaust!
Hi guys!
There is white, sometimes mixed with blue smoke going out from the exhaust!
And it's more goes out when I shoot the pedal gas down!
When I go slow, I don't see any smoke, but when I stop,
there is a freaking fog and smells terrible, also my exhaust tips are black, looks like an oil coating.
What do you think, guys? How to solve this problem, and who did?
Stock exhaust, no cats.
      01-11-2012, 11:42 AM   #2
triggz
Drives: E92 335i
turbo seals are finished...turbos need to be replaced
Same thing happened to me when I went full catless.
As soon as they replaced the turbos, no more smoke.
      01-11-2012, 12:35 PM   #3
Island Road
Drives: 335i
2008 335i  [10.00]
x2
I have all the same symptoms as you after going full catless. Turbo seals are gone time to upgrade!
      01-11-2012, 12:38 PM   #4
Syndicategt
Syndicategt's Avatar
Drives: 335i
Like the others mentioned, most likely turbo bearing seals are leaking oil in your turbos, causing the blueish smoke. Cats cover up the smoke, so it will become more pronounced when going catless. Have them inspected, most likely you will need them replaced. If out of warranty, give Rob Beck a PM
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
      01-11-2012, 03:02 PM   #5
T!m3
BMW maniac!
T!m3's Avatar
Drives: ///M3 e92
I'll check them soon, maybe even the turbos can be repaired)
According to the results will let you know)
      01-11-2012, 03:23 PM   #6
triggz
Drives: E92 335i
you cant repair them if the seals are finished
new turbos my friend
      01-11-2012, 03:24 PM   #7
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
      01-11-2012, 06:31 PM   #8
mpower3o2
Drives: 2017 AP M3
when going catless, this is one risk you have to take? If so, is there anything we can do to prevent the seals from going out before the downpipes are installed?
      01-11-2012, 06:54 PM   #9
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
From my understanding the cats cover up the smoke which would hide this problem. Therefore going cats has no ill effect and would actually tell if your turbo are going bad?
      01-12-2012, 09:09 AM   #10
triggz
Drives: E92 335i
exactly!
      01-12-2012, 10:14 AM   #11
hemi to e90
dat boost doe
hemi to e90's Avatar
Poland
238
Drives: 10 335i 21 740li
your turbos can go if you are catless or catted, their presence has a debatable effect on the turbos longevity.
granted catless sounds better and reduces backpressure.
      01-12-2012, 11:06 AM   #12
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
Whether you have cats or not has little bearing on the turbo seals, just the symptoms.
      02-12-2012, 01:39 PM   #13
T!m3
BMW maniac!
T!m3's Avatar
Drives: ///M3 e92
Soon will come the new turbos.
But what if it's not a turbo seals.
Could there be a problem in the valve cover, valve stem seals, pistons, or something else?
By the way, put the oil catch BMS, no difference, still smokes and burns oil so much, about 1 litre in 300-400 km.
What do you think?((( Why its so much oil going out??
      02-12-2012, 02:16 PM   #14
dzenno
Drives:
You also may have an oil leak somewhere..what's the mileage on the car? Check the front of the engine, see if you can spot a leak coming down from the oil filter housing down the front of the engine block...oil filter housing gaskets are known to go on this and earlier bmws
      02-12-2012, 02:51 PM   #15
T!m3
BMW maniac!
T!m3's Avatar
Drives: ///M3 e92
85 000km.
I already changed the 2 gaskets on the oil filter, there was some leak...
But it didnt help!
And again, I have to add 1 litre per 300-400 km
such a number can not be due to external leakage
      02-12-2012, 02:53 PM   #16
dzenno
Drives:
Does it smoke on cold start
      02-12-2012, 03:22 PM   #17
T!m3
BMW maniac!
T!m3's Avatar
Drives: ///M3 e92
Yes it does!
But its ok
the worse thing is when I push the pedal gas all the way down, then it smokes like a train!
      02-12-2012, 03:24 PM   #18
dzenno
Drives:
If that's the case check your valve stem seals and valve guides...its quite possibly them
      02-12-2012, 03:25 PM   #19
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
Вытащи свечи и посмотри если на них масло есть.
      02-12-2012, 04:06 PM   #20
T!m3
BMW maniac!
T!m3's Avatar
Drives: ///M3 e92
Намекаешь на прокладку клапанной, или на трещину в ней??
Do you think that oil flows from the valve cover gasket or its crack in it?
      02-12-2012, 04:27 PM   #21
boostaholic786
boostaholic786's Avatar
40
Drives: E92 N54 with MHD Custom flash
I have no idea what you guys are talking about seeing I cant read whatever language that is haha but in my opinion its your turbo seals and maybe a leak if your going thru that much oil in that short of time... Sorry to break it to ya but thats what I think is wrong with it
      02-12-2012, 04:28 PM   #22
Tomaz
Drives: BMW 335i
Салам Bro!
I have faced the same problem, but have solved its replacement PCV.
e90post
