Need help with meth setup
01-10-2012, 07:36 PM | #1 |
Real Car Enthusiast
288
Rep 2,082
Ok, I have a piece milled meth kit and really need some guidance on how to install this correctly or if I even have all the parts I need. First off this is what I have:
Devil's Own Stage 1 Kit Snow FSB Coolingmist Solenoid BMS WW Conversion JB4 My delima is that the Snow FSB and BMS FSB are nothing alike. After emailing with snow, the yellow wire has an output of 0V to 1.5V. Is this the wire I hook up to the JB4? Will this FSB integrate like the BMS FSB does so that the JB4 can control the meth flow? Next is I'm not quite sure how a Solenoid works but they all look the same so I assume I'm good with the Coolingmist solenoid? I know that the Snow FSB green wire usually runs thier solenoid so I assume I connect that to the CM solenoid? Also the cheap DO pressure/boost switch. Do I still need to run this to the Vacuum or will the JB4 do this now? Please advise. |
