E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Weird Hum is KILLING ME!!!
      11-22-2011, 11:33 AM   #1
Edluver
Drives: '06 330Xi
I recently noticed that when I'm driving at a speed greater than about 30mph I start to hear this odd hum. As I go faster, the pitch increases but not in volume. It's driving me CRAZY!!
I just got my right front tire patched and I'm wondering if that's it but I can't hear it if I roll down the window - wind noise is too loud. Is there any way it could be the rear diff?
Any ideas on what it could be, how to fix it or at least a way to tell if its coming from the diff?
Thanks in advance for the help.
      11-22-2011, 11:52 AM   #2
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
Hmmmmmmm....
      11-22-2011, 12:00 PM   #3
CoralRed335XI
Drives: 2008 E92 335XI Coupe
2008 BMW 335XI  [3.66]
Originally Posted by ajsalida View Post
Hmmmmmmm....
d*ck. lol
Sounds like a bearing issue. Now you just need to find which wheel or drive shaft it's coming from.
2008 E92 335XI, Space Gray on Coral/Fox Red Hybrid M3 seats, Premium, Cold Weather, Comfort Access, iPod.
Mods: Fox Red M3 seats up front, KW V1, ER CP + TIAL BOV.
      11-22-2011, 03:00 PM   #4
ajsalida
ajsalida's Avatar
226
Originally Posted by CoralRed335XI View Post
d*ck. lol
Just havin' some fun. I'd swap tires side to side or F/R depending on sizes and see if there's a change in sound first. Carefully look over the patched tire to see if there's a plug sticking out.
      11-28-2011, 04:47 PM   #5
b00sted4v
Drives: 2008 335xi
id say wheel bearing
      11-28-2011, 04:57 PM   #6
jlcolon2001
Drives: 335i Coupe 2007
+1
      11-28-2011, 06:51 PM   #7
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
I think you should have your transfer case and diffs looked at. Check fluid levels to start.
      11-29-2011, 11:51 AM   #8
Edluver
Drives: '06 330Xi
I took it to the dealership over the weekend and took one of the techs for a ride (I had to insist, as the dealership really didn't want to do it). The 12 year old that they had ride with me says that it sounded like a tire issue and not a a bearing. Hopefully he's right but I'm gonna check the diff fluid this weekend.
Timujin352.50
      12-06-2011, 08:04 PM   #9
sk8board511
sk8board511's Avatar
Drives: 07 E90-Bikes on bikes on bikes
I had a bad Hum off my tires, i swapped them and the ride couldn't be quieter...minus the sweet sound of my exhaust
KING"ish" OF Changed for collins
      12-22-2011, 07:34 AM   #10
Eppieguy
Drives: 08 328XI
I have the same type of noise, 09 328xi automatic. It's what a call a grinding / humming noise but it also has a thumping noise only when you let off the gas, most noticeable between 40-60 mph, kind of sounds like a out of round tire noise but goes away as soon as you step on the gas. I took it to the dealer and they "assume" it's low on fluid due to an accident the car was in 30k ago! I just bought the car, first BMW for me so I'm not sure how to proceed. I have known the car since new, i know the damage that was done in the accident and it was fixed 30k ago so its hard to accept this problem is due to the accident. Any ideas for me? If it's just low on fluid where to I go to check it? I'm a do it myself kinda guy and I can turn a wrench so any suggestions would help.
Thanks
      12-22-2011, 12:03 PM   #11
325xi-06
manifold conversion 325/330
325xi-06's Avatar
Faroe Islands
Drives: 325xi 06
check if it gets louder when you put your ear next to the rear air went... or have someone else put there ear for you :P
      12-22-2011, 09:09 PM   #12
Eppieguy
Drives: 08 328XI
Do I dare ask why?
      12-23-2011, 02:26 PM   #13
rtgirard
1-5-3-6-2-4
Drives: Awaiting 2013 335xi -
i had my front-right bearing replaced under warranty at 12k miles. It began like a hum that I really thought was tire noise, but over the course of time it got louder and louder (even after rotating tires). Finally, any time I was over 40mph it was ROARING.
Dunno what the OP's hum sounds like, but if it gets any louder with time or is still exactly the same after moving tires around, I vote for a bad bearing.
      12-23-2011, 07:42 PM   #14
Eppieguy
Drives: 08 328XI
Thats what I think it is but the dealer is hanging thier hat on the car was in an accident and it's not thier problem, the accident was 25,000 miles ago but I can't get them to budge, my warranty is up at the nd of January.
      12-23-2011, 10:23 PM   #15
csquared013
Drives: Arctic metallic 2006 330xi
my mothers 328 had a humming problem that sounds just like that with pitch increasing as speed increases. ended up being diagnosed as an issue with the front differential unfortunately. gl with finding a solution!
      12-26-2011, 11:00 AM   #16
danchee
Drives: 21 X7 40i
Eppieguy - Call up BMW NA. Complain to their customer rep that the dealer is not honoring warranty and this is not the kind of treatment you expect from a luxury brand like BMW. I've done that many years ago when the dealership refused to fix something under warranty (a long time ago on my E46) and I got a call from the dealership's manager to bring my car in for repairs. They even did a full inspection and fixed everything that can be fixed under warranty plus a complete car detail.
YMMV of course, but no harm in trying.
      11-28-2012, 03:53 PM   #17
Likwid
Drives: 2007 M5
Wow, same issue here...2008 335xi. The pitch increases as the speed of the car increases, but has nothing to do with engine speed. I would think that this means it is something beyond the output shaft of the transmission, meaning transfer case, drive shafts, wheel bearings, axles, or tires. The sound is louder when the car is under load (accelerating or engine breaking) and when it is not under load, it gets quiet. I had new tires installed in August, and I was thinking that could be the cause. I will try rotating the tires around to see if the sound moves with them, but I really am leaning toward something with the transfer case.
      11-28-2012, 04:04 PM   #18
Koreyy
KOrey
Drives: 335i Coupe
2008 BMW 335i  [0.00]
http://www.e90post.com/forums/showthread.php?t=775251 check this video in this thread. sound like that?
      11-28-2012, 04:06 PM   #19
Amini77
Drives: Alpine White '13 550i
2013 BMW 550i  [0.00]
I'd say it was the bearing also, when your going about 5mph do you hear any wheel rotation squeaking?
      11-29-2012, 09:55 AM   #20
Patrick303
Patrick303's Avatar
Drives: F36 440i GC
A coworker of mine just had new tires mounted on his truck. As soon as he left the shop he said he had symptoms similar to yours...humming noise with higher pitch at higher speeds. He went back to the tire shop and discovered that they mounted one of his directional tires backwards.
Since you just had a tire removed from the rim for a patch, you might want to check to make sure they mounted it the right way.
2024 Porsche Taycan 4S
2017 Ducati Monster 821
      01-22-2013, 03:46 PM   #21
E36graduate
E36graduate's Avatar
58
Drives: 2013 335i M-Sport 6MT
Here is what I would do as I went through this about 30,000 miles ago thinking the worse that my front differential was toast......but it wasn't.
I ended up changing both front wheel bearings...funny thing is the side I thought was making the noise was actually the opposite side. I originally thought it was the drivers side front bearing as that is where the noise seemed to be coming.
Then I thought it may be the front differential as it is on the drivers side and looked to be leaking. Put in fresh oil, thicker and noise still there.....then panic set in as there were only 2 used front diffs in the country, or spend $2000 on a new one.
Finally, my neighbor got my car up on his lift and we determined the front passenger wheel bearing was making some noise, but that didn't cure the problem........ended up finding the fron KW V1 struts were shot on the drivers side....absolutely toast.
Put new struts on and the Humming noise went away! Must be the struts dampen the noises from the wheels and road...basically with a blown strut I had all the vibrations and noises go from the wheel right up through the steering wheel.
2008 335xi - 6MT - BMS JB4 G5i - BMS DCI - BMS OCC - BMS WW Meth - Spec Stage 2+ - Spec SMFW - 19" MVR Magnum's - KW V1's - TMS 12.5+20mm Spacers
      07-28-2014, 08:45 PM   #22
stashtrey
Drives: 08 E90 335xi TiAg
I know this is old...but this post is exactly what I'm dealing with right now. I did every single thing you've done except put it on a lift.
I pulled the front drive shaft and think the noise is the output shaft on the front diff as it has some rotational slop. However...the noise started the day I put my used KW V3's on. I will be pissed off like a mother trucker if one of the struts is blown. Arghhhh!
e90post
