garage door opener
05-13-2007, 10:35 AM | #1 |
e92 Arrived 5/12
Rep 86
garage door opener
I believe reading in the manual that the integrated garage door opener works when the car is off, although, I'm not finding that to be the case.
I was able to program it perfectly and it works great when the car is on, but not when it's off or even in radio mode. I also looked to see if the LED lights up when the car is off, but it does not which leads me to believe that it is not getting power when the car is off. Anybody else have this happen to them? Thanks. |
05-13-2007, 10:37 AM | #2 |
274
Rep 6,510
I like the fact that it does not work while the car is off... keeps theives from braking your car window if you park outside, and then having full access to open your garage... There was a lot of this going around for a while...
05-13-2007, 11:58 AM | #3 |
STEVIL Empire
218
Rep 6,297
Sorry, don't have the homelink feature but I have also noticed that when the ignition is off, the brake lights don't illuminate either.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
05-13-2007, 12:07 PM | #4 |
Rep 582
I can't get the homelink bit to work with my garage door. I can get my own door openers to work, but not the bmw homelink on the visor.
dunno...tried everything the manual said to do, both random code and fixed...nothin. Oh well. |
05-13-2007, 12:15 PM | #5 |
///M Specialist South Shore BMW
770
Rep 7,108
I was having the same problem.I just kept messing around with it and finally it worked.Unfortunately I have no idea what I did, but it works.I say keep trying different things.you might just get it.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
05-13-2007, 12:23 PM | #6 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
First you need to reset the button from the garage unit then program the remote and last step is pair it with homelink on your car that would solve the problem. Many of the new garage opener has the rolling code and it take a bit extra time to get it set up.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
05-13-2007, 12:26 PM | #7 | |
Rep 582
no worries, not all that important - i'll be moving in a couple months, i'll try it again with the new place. |
05-13-2007, 01:42 PM | #10 |
Rep 16,407
05-13-2007, 02:44 PM | #11 |
Rep 2,041
Drives: e93-35 May08 ED
Mines does not work when the ignition is off.
Same as the stupid sunroof which is the worst. :mad:
5-2-08 e93-35 ED Montego w/Jade Grey, Step w/Paddles, PP, SP, CA, hot seats and iPod.Awaing re-delivery soon.
Debadged 330xi ED 11/14/05 Auto/Mystic Blue/Gray leather with Alum/PP/SP/CA/Fold-down rear seats/Alarm. Sold to Carmax on 6/7/08 with 50,624 miles on clock |
05-13-2007, 03:47 PM | #12 | |
Rep 12,276
Took me 30 seconds to program mine. This time. But that's because I had my '06's as practice. First time took me a couple of days and some phone calls. You probably have a rolling code opener, so try these steps: 1. Clear the system by pressing buttons 1 and 3 until you think your fingers are going to fall off, or until you get the flashing tiny red light that you can barely see. 2. Set your handheld opener to the system by pressing the desired Homelink button and the handheld opener at the same time, also for several seconds until you see the fast blinking. HERE'S THE TRICK - hold your opener between the windshield and the mirror. These systems seem to have a really tough time in any other position. 3. On your garage door opener, press the "learn" button - and within 30 seconds, press and hold the assigned homelink button. The real trick you won't see in the instructions is the positioning of the hand held unit when learning your code, in step 2. Rotsa ruck!!!
I think it is bad luck to be superstitious |
05-13-2007, 03:50 PM | #13 | |
Rep 12,276
Remember that while the garage door is the common use for Homelink, it is not the only thing you can control with it. It is a security measure, and a safety measure. Would you want your kids to be able to mess with the buttons while you're out of the car too? BTW - in the '07's you can open and close the sunroof without the ignition or even radio ready mode. Ha ha.
05-13-2007, 04:04 PM | #14 | |
Rep 582
Thanks man, I will give that a try. I did try holding the handheld opener near the button...but not between the mirror and the windshield. Either I have poor reading skills (I don't) or the manual seems a bit vague in its direction as to how this is to work |
05-13-2007, 04:24 PM | #15 |
pull my finger to get your kinder® surprise
148
Rep 10,455
+1
05-13-2007, 05:56 PM | #16 |
Rep 12,276
The manual doesn't mention that, but it's a commonly known trick for the Homelink support folks. Works like a champ for me, every time.
05-13-2007, 07:43 PM | #17 | |
Rep 2,041
I was referring to the sunroof.
05-13-2007, 09:42 PM | #18 |
Rep 89
Thanks for the tip! I have tried a couple times before and gave up on programming mine. Holding the opener between window and mirror worked like a champ.
Space Gray / Saddle Brown / Aluminum / Sport Pkg / Premium Pkg / Auto / Navigation / PDC / Comfort Access
05-14-2007, 10:39 AM | #19 |
e92 Arrived 5/12
Rep 86
I'm not sure if I got my question answered yet? I have a e92 335i and the garage door opener is built into the rear view mirror. It opens the garage door fine when the car is on, but when I turn the car off it does not work.
I think it's programmed correctly, I think the manual may be wrong because it says I can open the garage when the car is off; although, I haven't found that to be the case. Thanks. |
05-14-2007, 11:17 AM | #20 | |
Rep 2,317
and it doesn't work when the car is off. But that's fine by me, my car seems to always be on when I'm coming home or after I pull out of the garage. |
05-14-2007, 11:38 AM | #21 |
Rep 2,032
i can't seem to get the garage door opener to work either.
after the steps where i press the garage remote and the button on the mirror it flashes 2 times and then very fast. so it seems ot connect. but when i try it the door doesn't open |
05-14-2007, 04:39 PM | #22 | |
Rep 582
Men don't need manuals. Heh, well I know - I saw that number, but you know how it is...last resort. Sort of like hitting the on this forum. In any event I am about to go give this a shot, I expect it to work. If it does not - there will be fur flyin. Thanks. |
