328xi winter vs all season tires
11-16-2011, 01:41 AM | #2 |
No 55mph
1622
Rep 8,476
Some will adamently say that snow tires are not needed - I run snow tires here in PA.
Only had trouble with the all season's on the worst of days when it had snowed 8+ inches as far as starting out, but found the snows were much better as far as stopping/turning in any amount of snow. I go in to work early in the AM before any plows touch the road - basically it's just drive where ever you want on the entire road as they are totally covered and there is hardly anyone else on the road. I like the added security of the snow's so I don't have to concentrate on driving differently in deep snow.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
11-16-2011, 07:20 AM | #4 |
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
I have been running all season tires in the winter for 2 winters now here in Toronto. I have been caught in some big snow storms here and had no issue. The 328xi was able to get out of any situation I was in.
That being said, my all season are worn and I will be replacing them with winter tires (got a good deal). Will be my first winter driving on snow tires for this car. Last edited by DESI4life10; 11-24-2011 at 04:37 PM.. |
11-16-2011, 07:54 AM | #5 |
Rep 2,387
Where I live people who really need snow traction use studded tires or chains on AWD or 4WD vehicles. Our local ski area has already got over 100" of snow this season for example. Anything less than studs/chains is pointless in the conditions you'd need them for. Since I don't want to do that I do not drive the Xi under those extreme conditions, and use Conti DWS in the 99.9% of other times, most of which involve clear pavement. It is a good year round AS tire and an excellent snow tire, outside of where you'd want studs/chains. In those conditions (super deep wet snow) they do OK but you need to be very careful.
So I am saying that snow tires alone (no studs or chains) are not the end-all of snow traction, you can still get stuck. IMHO the additional capability a set of snows only + AWD gives you over a set of good AS + AWD is not worth the hassle and extra wear, and poor dry performance. Super deep snow is why I have a 4WD pickup truck with M+S tires. And in my experience at least the limiting factor is ground clearance, which no tire will give the Xi over a truck. PS: I live near Wolf Creek ski area, they get apprx 500" of snow a year on average, in town we only get 20 feet or so. Last edited by ajsalida; 11-16-2011 at 08:00 AM.. |
11-16-2011, 11:25 AM | #6 |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
If you have the money, I'd suggest getting true winters. If you dont' want to spend the dough, you'll have a bit lesser drivability no doubt, but you'll be fine with good A/S rubber.
Down here in Boston, I run pure summers and winters for each season. Just threw on the Nokian's a week ago. Figures, it's been 65 degrees since I did it. |
11-19-2011, 01:52 PM | #8 |
Waaka Waaka
41
Rep 486
I think you should want summer tires for the performance and look (get biggger wheels than OEM), this means you can run the all seasons as winter tires, or buy separate winters.
All seasons are fine in toronto with an xdrive but winters are just awesome. I was caught in snow storms up north last year and the handling with winters and xdrive was almost summer like. |
11-22-2011, 04:18 PM | #9 |
Bavarian Fever
34
Rep 1,108
I'm running non runflat, all seasons (Conti DWS) for the first time this winter in NJ. I anticipate solid grip and traction in light to moderate snow and I probably won't drive in heavy snow conditions...
| ESS n52 Tune | BMW Performance Intake/Exhaust | LUX H8 v3 AE | GP Thunder 8500K fogs/corners | LED: signals/interior | V1 hardwired | debadge | AC pedals | Performance shift knob/boot | CF e-brake | Aero lip | m3 side skirts/spoiler | MB kidneys | Strut brace | Painted reflectors | Painted Calipers/Hubs | 35% 3M tint | Smoked tails | CF Roundels | 19" Miro 942 | Conti DWS | H&R Springs for xi | Bilstein Shocks| Nxt: Alpine Subs/Amps
11-24-2011, 03:48 PM | #11 |
No 55mph
1622
Rep 8,476
You'll definitely be happy with the Blizzaks - that's what I have and there was no problem getting thru any snow - even after a storm that dumped 22"
11-24-2011, 08:16 PM | #12 |
Rep 128
Since my dad can fall back on his Suburban with snows, he leaves the all seasons on his 07 328xi. I put snows on my 06 325xi, and having driven both in the snow back to back, the snows do make a huge difference. And honestly, the only advantage the Suburban offers over the BMW with snows is ground clearance. The traction and stability controls work great with the right tires. That said, if there's ice, just stay home.
I put 16" LM-25s on first, and having swapped to non run flats for summer, I put WS-70s on for this winter. You won't get the same feel/handling in dry, clean roads, but it makes up for it in snow and slush. |
11-26-2011, 03:50 PM | #13 |
Rep 1,188
Drives: 2008 e92 335xi
People always state they get around with all season tires in the winter without any problem, which I'm sure is generally true. However, if you ever get into an emergency situation when you have to stop/start/turn etc that's where dedicated snow tires will really show their worth and can save you from accidents.
11-26-2011, 04:09 PM | #14 |
Chief Executive
300
Rep 2,886
Just put these on my wife's AWD turbo S40. I'm veryimpressed. Huge improvement over the Michelin A/S rubber she had on there. She's lead footed, so I really didnt have an option to cheap out. Money was very well spent. Looking forward to see their snow performance, but they passed the dreaded wet leaves test, so I think they'll be very nice.
12-08-2011, 09:12 AM | #17 | |
Rep 5,538
high performance winter tires are also excellent in dry and wet edit: the only place for all-season tires is when your winter season is around 30-40F and very little or no snow at all. summer tires are no good at those temperatures and snow tires are overkill for 30F. I know people in this forum do this. Last edited by Kolyan2k; 12-08-2011 at 11:57 AM.. |
12-08-2011, 10:44 AM | #18 |
Rep 415
Drives: 2011 335i X-Drive Sedan
I'm putting on my Dunlop Winter Sport 3D's tonight! Love them!
2011 335 X-Drive E90 MTECH 6MT • AST4100's • Vishnu 3.5" DP • Helix FMIC • Procede V5 • M3 Strut Brace • M3 Trunk Lip • LUX H8 • 19" Alufelgen SF-71: 8.5' front, 9.5' rear • Continental ExtremeContact DW Tires
12-08-2011, 12:58 PM | #19 |
Rep 125
12-08-2011, 01:33 PM | #20 | |
Rep 2,387
Most AS tires I'd agree with you. However, If you haven't driven a set of DWS, you might want to try them. I thought the same as you but after quickly wearing out multiple sets of very expensive hi-perf snow tires on dry pavement I got tired of it. Anyway, DWS has very good to excellent snow perf and excellent treadwear & handling otherwise. Not ultimate summer tires by any means but I need some snow/ice capability maybe up to 8 months of the year. As for snow I live at 8k ft and drive to 12k ft often. We have much fresh snow on the roads now and hardpack. And dry pavement. Last few days have been sub zero deg F in the AM, the DWS are outstanding on un-sanded plowed ice/snow roads. Way better than my 4WD Tacoma with new M&S tires, on the same exact roads/conditions, though that is more a function of weight distribution and smarter AWD. They are very good in unplowed snow up to about bumper/spoiler height and then the Taco takes over for the real deep stuff. |
12-08-2011, 02:01 PM | #21 | |
Rep 5,538
