12V+ Ignition from Bluetooth harness in trunk
11-09-2011, 05:28 PM | #1 |
Rep 94
Hi
Help please I want to install an amp and processor into the trunk of an E90 LCI with base stereo. I need to tap into a 12V+ wire that is hooked up via the ignition switch and don't want to pull out the head unit. Does anyone know whether I can tap into the Bluetooth harness in the trunk to get a 12V+ connection and if so which wire Thanks |
11-09-2011, 06:18 PM | #2 |
Rep 13,104
You better look at some of these install examples
Because everybody runs there +12 right off the battery(for the amp) running number 4 cable . (or at least number 8) ( I have only seen aftermarket head units connected at the fuse box on this car)(and never seen anything connected
at the blue tooth or TCU) http://www.m3post.com/forums/showthread.php?t=540446 http://www.e90post.com/forums/showthread.php?t=540954 If I were you I would be looking at getting a technic harness which comes with power cables and will allow you to hook up your equipment without cutting any factory wires. Also I would be looking at as many installs on here as possible till you understand how to approach this. If you haven't already bought equipment I would consider a one stop solution from these guys. http://www.musicarnw.com/page-2/ Last edited by ctuna; 11-10-2011 at 03:05 PM.. |
11-10-2011, 03:01 PM | #4 |
Rep 13,104
Have you considered the current draw
A seperate amplifier of any significant size requires a cable that won't melt
or restrict the flow of current when its pulling any significant current. Do you know the current rating of the cigarette lighter? Last edited by ctuna; 11-10-2011 at 03:18 PM.. |
11-10-2011, 03:34 PM | #5 | |
Rep 7,089
Drives: '06 AW 330xi
When you shut your car off, the radio still plays but your amp will shut off. You can buy a line output converter that has a built in remote trigger. Technics harness has this. It is also plug and play and the cleanest solution. Btw guys I think the OP is looking for a remote trigger. Not a 12v source to power the amp. |
11-11-2011, 05:41 AM | #6 |
Rep 94
Thank you for the responses everyone.
I am looking for a remote trigger only. The amp & processor will be connected directly to the battery (with fuse & 4AWG & 16AWG cable etc). I will either use an Audison Bit10 or JL Cleansweep to flatten the EQ - the Bit10 also has EQ/time alignment functions etc. Both of these units have remote turn on function so they will automatically switch on when a signal from the OEM head unit is detected. The JL Cleansweep has the following connections to power up: - 12V+ (constant - direct to battery) - Ground - 12V+ (via ignition switch) - This is the wire that I am looking for Maybe one way is to connect both the 12V+ constant and 12V+ ignition directly to the battery and let the auto turn on/off function work - Can anyone confirm this approach? Or the 12V+ via ignition is not required? Can anyone confirm this one please? The Cleansweep / Bit10 will then provide a remote turn on signal for the amp. I have been in touch with Technic and his harness will need to be connected to the OEM head unit. I would rather not remove the head unit if I don't have to. I can take the signal from the front speaker & under seat sub to feed the CleanSweep/Bit10 without removing the head unit (this is similar to the wiring for the Alpine upgrade). Other equipment to be installed are: - earthquake SWS8's for under seats - JL HD 600/4 - Morel Hybrid ovation for front doors |
11-11-2011, 06:20 AM | #7 | |
Rep 13,001
11-11-2011, 06:36 AM | #8 |
Rep 7,089
You'll want to change that 16AWG cable to a 4AWG.
11-11-2011, 03:30 PM | #9 | |
Rep 270
Not if he's looking for remote turn on. As he stated he is.
11-11-2011, 03:35 PM | #10 | |
Rep 7,089
The power and ground should be the same gauge. You're right, the REM wire can be 16AWG.....but the way the OP typed it out, it seems like his ground is much smaller than it is recommended to be. As for finding the REM lead on the L7 amp harness, there is none. It is turned on through the MOST loop. OEM REM lead is pin 13 at the HU harness.....but OP mentioned he doesn't want to pull the HU. EDIT: He has base, not L7. So the last section of this post is partly irrelevant. But the base stereo doesn't have an amp in the trunk either. It's still pin 13 behind the HU. Last edited by fdriller9; 11-11-2011 at 03:57 PM.. |
11-11-2011, 03:54 PM | #11 | |
Rep 270
