E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Help No Amp!!!!
      11-07-2011, 11:14 PM   #1
LORIA335i
Drives: 2007 335i Coupe
Help No Amp!!!!
Hey guys just got my car and i guess someone robbed the amp out of it, i was wondering if anyone has one for sale cheap or if i can just use a regular amp and cut the harness, anybody do this before? if so do you have a diagram or wiring guide?
Thanks, Justin
      11-07-2011, 11:20 PM   #2
hogbmw
Drives: '07 BMW 328i
Are you sure you have no amp? The stock amp is hardly worth robbing... Pretty sure the lowest sound system doesn't have an amp at all. Maybe a stupid question but does the music work?
If u want to wire a new amp best route would be to get a technic harness which plugs into stock wire harness and gives you plugs for an amp.
'07 328i-Saphire Black Murdeerrrrred-gone
'08 335i-Black on Gold.. work in progress!-JB3-DCI
      11-07-2011, 11:23 PM   #3
LORIA335i
im pretty sure i have logic 7, and the space in the driver side of the trunk is empty with two harnesses just laying there, the radio works and everything just no sound...
      11-07-2011, 11:45 PM   #4
hogbmw
Oh damn well mabe u should talk to whoever sold u a car without an amp. The Logic7, if you have it, is a special connector ud have to get a new or used amp from someone I believe.
      11-08-2011, 01:10 AM   #5
ctuna
Drives: 325xi 06 wagon MT
You need to find out for sure what it had.
Maybe run the Vin number at BMW to see what options it came with .
If the radio has and equalizer option and you have a center speaker in the dash then you have logic 7.
If its logic 7 a regular amp won't work because it uses a Fiberoptic connection from the Head Unit to amp. Only the original Logic 7 amp is capable of using
that signal.
If its not logic 7 and is Hi Fi no wires need be cut you just need a technic harness and and aftermarket amp . (like a Jl xd 600/6 , 6 channel ) there are other amps to that will fit but most aren't 6 channel. You probably should upgrade your speakers if you do this.
http://www.e90post.com/forums/attach...2&d=1266451970
http://www.e90post.com/forums/attach...2&d=1260829447
      11-09-2011, 11:03 AM   #6
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
Thanks, Justin
There is a logic 7 amp for sale in the classifieds and it looks like it was just cut out of a car! You didn't get the car from FL did you?
      11-09-2011, 11:06 AM   #7
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
FYI Logic7 amp worth about 600-700 on ebay.
e90post
