2010 E92 Base System Upgrade
11-05-2011, 02:40 PM | #1 |
Rep 62
Hi, I would like to upgrade my 2010 E92 Base audio system and needed some guidance. I do not want to spent a lot of money and I will not be doing the install so looking for the most bang for the buck.
I was thinking to do the following to to keep it least invasive: Replace Front Speaker with Logic 7 speakers (Already have L7 speakers) Add the L7 tweeters Can someone give me the BMW PN for the Sails to install the tweeters Add XD600/6 or MS-8 I am not planning on replacing the underseat speakers rear speakers. Do you guys think this is a good idea ? I am open to suggestions and also looking to find a good shop in Nor Cal to do this upgrade for me. |
11-05-2011, 03:46 PM | #4 |
Rep 13,104
You will need a JL cleansweep
You will need a JL cleansweep or some other kind of
processor or amp/processor to flatten out the head unit output. If you haven't bought anything yet I would get in touch with these guys for a a one stop shopping solution. http://www.musicarnw.com/page-2/ They can sell you a kit with everything needed that plugs into the factory connectors. It comes all setup so no soldering or crimping and little if any adjusting is needed. If you really don't want to replace the underseats I think you might be OK with just the amp and JL Cleansweep. If you want fantastic bass you should replace the underseats though. Last edited by ctuna; 11-05-2011 at 03:51 PM.. |
11-05-2011, 05:22 PM | #6 |
Rep 13,104
This is why you need a processor
You can't tune out the factory eq
http://www.e90post.com/forums/showth...ighlight=graph You are very likely to fry the under seats with an amp. Also most shops are not competent on BMW's Last edited by ctuna; 11-05-2011 at 05:31 PM.. |
11-05-2011, 06:21 PM | #8 |
Rep 3,969
MS-8 works GREAT with (and only with) L7 speakers. Underseats require external amplification.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
11-06-2011, 09:27 AM | #9 | |
Rep 4,121
11-06-2011, 09:34 AM | #10 |
Rep 4,121
See here for part numbers. Pick vehicle with l7 and you will need part 13
http://www.realoem.com/bmw/showparts...86&hg=51&fg=10 |
11-10-2011, 11:40 AM | #11 |
Rep 62
What are your thoughts about the following system, in comparison to VP's Stage 1:
Audison Bit Ten sound processor (2) Audio System 8” subs for under seat Focal 100 VRS – front Focal 100 CVX – rear JL Audio XD 700/5 or Alpine PDX-5 If you have a better recommendations I am open to that. I dont want it to be invasive so I am not interested in center console speaker. Do you think tweeters are a must ? |
11-10-2011, 02:53 PM | #12 |
Rep 13,104
If you want a one stop solution
With known to work and tested configurations that includes
Factory connectors , and amplifier and/or processor that is already set up or has sound files ready to go. e9x specific technical support. They will also customize the system to your tastes. get in touch with these guys http://www.musicarnw.com/page-2/ There will be no hair pulling or guessing involved. |
05-17-2013, 08:16 AM | #13 | |
Rep 94
Did you go with the Bit Ten?
