6FL - Can it be installed afterwards?
10-24-2011, 09:45 AM | #1 |
Rep 25
I have a 2006 E90. I only have the AUX jack in my center console along with the cigarette plug. I went to my dealer the other day to inquire about the 6FL. I was told that unless I ordered the car with the 6FL option, I wouldn't be able to put it in my car. Is this true? I find it hard to believe. Thoughts?
10-24-2011, 10:14 AM | #2 | |
Rep 13,001
The only way of even trying to retrofit the 6FL is to replace your radio with a MY2011 and then add the Combox. That's not 100% guaranteed to work or cheap to do. |
01-08-2012, 03:59 PM | #4 | |
Rep 140
do you have Idrive Professional? If so get this kit, 65-41-04-45-465 is the PN, around £250 in the UK and you will need a High MULF 2 with USB support....the above kit does not include the MULF2, look on ebay for a cheap one... finally get a autologic place to code your car for USB....done.. search on the forum, plently of 6FL (USB) success stories.. all comes down to cost at the end of the day... |
01-08-2012, 04:06 PM | #5 |
Rep 13,103
Whats the best aftermarket 6fl?
Mobridge or Denison or are they 6fl(USB)?
I guess what I am asking is how do I get USB on an 06 car and apparently this is different than a iPod interface? Last edited by ctuna; 01-08-2012 at 04:17 PM.. |
01-08-2012, 04:13 PM | #6 | |
Rep 13,001
01-08-2012, 05:37 PM | #8 |
Rep 13,001
01-08-2012, 10:20 PM | #9 |
Rep 13,103
Is the OEM ipod kit for 06 digital?
Does it deliver digital input to the Head Unit and control the ipod or does it basicly only and analog input with steering wheel control ? Of can it be retrofitted at all . How does it differ from USB? Since most of the aftermarket kits operate through the CD changer interface how does this differ as that seems to be a digital connection over the most bus? |
01-08-2012, 10:44 PM | #10 |
Rep 2,809
If you're concerned about the USB...why not just get a USB cigarette adapter? Or did you want the controls to work as well? Too much of a hassle if you ask me.
01-09-2012, 06:30 AM | #11 | |
Rep 140
I have a 2007 (01/07 - build date), latest updates, radio without the programmable buttons and retrofitted Dab and CIC controller (computer is still CCC). For my car I already have the USB showing up greyed out as I had that programmed by my Indy... Just getting my USB kit today: 65 41 0 445 465 USB/audio interface retrofit MULF 2 later this week.... hoping it will work, will keep the forum updated.. Thanks... Technic - ont more question for you as I hear you are the guru! If I have the Alpine retrofit Hifi, what is the best way to add rear shelf speakers? appreciate the response. Regards, Tich. |
01-13-2012, 11:01 AM | #12 |
Rep 762
I have been researching this for a while for my 06. I just pulled from a wrecked 09 E90 yesterday the headunit, wiring, Mulf 2 with bracket, and USB/Aux port in center console for $200. Hopefully all works when I install Figured it should since everything came from same car
01-14-2012, 10:24 AM | #13 | |
Rep 1,404
Keep us informed to your progress.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
01-28-2012, 10:29 AM | #14 | |
Rep 140
I think I need the BMW CCC Radio with the 6 buttons, can anyone help and clarify this? appreciated... so close yet so far! |
01-28-2012, 10:31 AM | #15 | |
Rep 13,001
Most likely all will work without coding. |
01-28-2012, 11:09 AM | #16 | |
Rep 140
USB on Idrive showing up: http://www.e90post.com/forums/album....ictureid=33216 Alpine retrofit and MULF2 under TCU on right: http://www.e90post.com/forums/album....ictureid=33217 Dab Retrofitted: http://www.e90post.com/forums/album....ictureid=33218 My dash with new controller: http://www.e90post.com/forums/album....ictureid=33219 USB in Armrest fitted: http://www.e90post.com/forums/album....ictureid=33220 |
01-31-2012, 08:14 PM | #19 | |
Rep 2,105
02-01-2012, 05:57 PM | #20 |
Rep 140
I've read a few threads on the subject but still confused what you exactly need...
Do I just need the new cic monitor, cic computer, usb for glovebox and new video cable? or is there more to it? thanks.
